1 Reply Latest reply on Sep 12, 2006 8:34 AM by Prpl_Ppl_Etr
    Function calling problem
    srib
      I created a class file and in constructor loading a XML file and on Load of XML I am calling different function with in the same class, but it is not executing can you please tell me where is the problem.
      Here is the code given below.
      class myClass
      private var myXML:XML;
      public function myClass()
      myXML.load("myXML")
      myXML.onLoad = function()
      displaText() // This is the function which is not calling
      public function displaText()
      trace("Welcome")
        • 1. Function calling problem
          Prpl_Ppl_Etr
          It looks like you've got a scoping issue...
          try:
          var pointer:myClass=this;
          myXML.onLoad=function(success){
          if(success){
          pointer.displaText();
          }else{
          // error handling
          When you call a function within an onLoad event, that function is scoped to the object being loaded. If you want to call a method from another object (in this case from your 'myClass' class), you need to use a reference to the object that contains the function.
          Don't forget to use the new XML constructor when instantiating your XML object:
          myXML= new XML();
          Also... it's a best practices thing... you should capitalize your class names (MyClass instead of myClass). You'd then likely use the lower case (myClass) to name an instance of the class.
          Cheers,
          PPE
