1 Reply Latest reply on Sep 9, 2006 5:26 PM by mirianam
    Vector shape to scale with text
    mirianam
      Hello
      I am needing some help with vector shape and text.
      The vector shape is a cartoon/comic book like box ( a rectangle with rounded corners and a spike pointing to persons mouth - sort of like a thought bubble) and I want to have changing text inside this vector shape.
      I am having trouble aligning the two.
      I am using the height property to change the height of the vector according to the amount of text but I can't work out how to calculate the offset (or whatever). I'm guessing that as text has reg point at top left and vector shape not. Can someone please give me some guidance.
      Here is the code for chaging the text. I'm using an empty text sprite as the text placeholderwhich is on top of my vector box
      property pTargetSprite --placeholder sprite
      property pMyTextMember --text which goes into the placeholder sprite postion
      property pMySprite
      on getPropertyDescriptionList me
      set pdList = [:]
      addprop pdList, #pTargetSprite, [#comment: "Which sprite is target?", #format: #integer, #default: 26]
      addprop pdList, #pMyTextMember, [#comment: "Which cast member?", #format: #text, #default: "placeholder"]
      return pdList
      end getPropertyDescriptionList
      on beginSprite me
      pMySprite = sprite(me.spriteNum)
      end
      on mouseUp me
      sprite(pTargetSprite).member = member(pMyTextMember)
      sprite(17).height = member(pMyTextMember).height + 50 --sprite(17) is the vector shape "cartoon speech box"
      end
      Thank you
        • 1. Re: Vector shape to scale with text
          mirianam Level 1
          In case anyone is interested this is what I have done. This moves the text down by half it's height and keeps it in the vector shape. It's not perfect.
          I tried to use rect.bottom but made no progress.
          property pMySprite
          property pMyAdjustment --amount to reposition the text member loc
          property pMyStartLoc --for text member
          set pdList = [:]
          return pdList
          on beginSprite me
          pMyStartLoc = sprite(pTargetSprite).locV -- the empty text placeholder
          end
          on mouseUp me
          go to "started"
          pMyAdjustment = pMyTextMember.height
          sprite(pTargetSprite).locV = pMyStartLoc - pMyAdjustment/2 -- text placeholder's new loc according to it's height
          sprite(17).height = member(pMyTextMember).height + pMyAdjustment --sprite(17) is the vector shape "cartoon
          end
