Expand my Community achievements bar.
Learn about Edge Delivery Services in upcoming GEM session
WebService and XMLListCollection
Avatar
Former Community Member
I'm new to Flex and I'm having some trouble with getting a
DataGrid to populate from an XMLListCollection and WebService. I
know that the data is being received, because it shows up in a text
area. Also, when I change the XMLListCollection to an
ArrayCollection it works fine.
<?xml version="1.0"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
layout="absolute" verticalGap="10">
<mx:Script>
<![CDATA[
import mx.controls.Alert;
</mx:Script>
<mx:WebService id="wsBlogAggr"
wsdl="
http://weblogs.macromedia.com/mxna/webservices/mxna2.cfc?wsdl"
useProxy="false"
showBusyCursor="true"
result="Alert.show('Received', 'Received');"
fault="Alert.show(event.fault.faultString, 'Error');">
<mx:operation name="getMostPopularPosts"
resultFormat="e4x">
<mx:request>
<daysBack>30</daysBack>
<limit>5</limit>
</mx:request>
</mx:operation>
</mx:WebService>
<mx:XMLListCollection id="xc"
source="{wsBlogAggr.getMostPopularPosts.lastResult}"/>
<mx:DataGrid dataProvider="{xc}" width="50%"
horizontalCenter="12">
<mx:columns>
<mx:DataGridColumn dataField="postTitle" headerText="Top
Posts"/>
<mx:DataGridColumn headerText="Clicks" dataField="clicks"
width="75" />
</mx:columns>
</mx:DataGrid>
<mx:TextArea y="245" width="307" height="160"
id="ta"
text="{wsBlogAggr.getMostPopularPosts.lastResult}"
horizontalCenter="0"/>
<mx:Button label="Retrieve XML"
click="{wsBlogAggr.getMostPopularPosts.send()}" y="476"
</mx:Application>
Sorry for the basic question, and thanks in advance.
Dan
1 Reply
Avatar
Level 2
You can go right from the WS result to the DataGrid when the
resultFormat is set to "object". Otherwise you should review this
document/sample for syntax and "caveats" -
http://livedocs.macromedia.com/flex/2/docs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=LiveDocs_Pa...
Have you given the "object" resultFormat a test?
creationComplete="initializeApp();">
<mx:Script>
<![CDATA[
private function initializeApp():void
wsBlogAggr.getMostPopularPosts.send();
</mx:Script>
wsdl="
useProxy="false"
resultFormat="object">
<mx:request>
<limit>5</limit>
</mx:request>
</mx:operation>
</mx:WebService>
<mx:DataGrid
dataProvider="{wsBlogAggr.getMostPopularPosts.lastResult}"
width="50%" horizontalCenter="12">
<mx:columns>
Posts"/>
width="75" />
</mx:columns>
</mx:DataGrid>
<mx:TextArea y="245" width="50%" height="50%"
id="ta"
</mx:Application>
