1 Reply Latest reply on Oct 30, 2006 5:35 AM by duckets
    Move text and graphic
    Level 7
      Hello:
      I have a text field and I need to add three heads or tittles within but
      these tittles must be graphics, Do you know how to scroll the text field and
      the graphics at the same time?
      Can you help me please?
      thank you
        • 1. Re: Move text and graphic
          duckets Level 1
          You can't insert graphics into text fields, but if you use separate sprites to display the graphics, you can use the 'scrolltop' property to determine the scroll distance of the text field. You could then use lingo to update the sprite's "locV" property to match using this. The sprites will be able to move above and below the rectangle of the text field though, so you may need to use some other sprites to frame the area and cover the sections above and below to hide the sprites in this case.
          - hope this helps!
          - Ben
