0 Replies Latest reply on Sep 12, 2006 12:45 PM by mooresm
    Flash CFGRID Not Recognizing Clicked Row
      I've got a CFFORM with a Flash grid that is inconsistent in recognizing a row has been selected. Running CFMX 7.0.2 on Windows 2003 server. Clients running Flash 8 & 9. The code is:
      <cfform action="temp.cfm" method="POST" target="_blank" timeout="600">
      <cfgrid name="tickets" query="qryOpenTickets" format="flash" width="800" height="280">
      <cfgridcolumn name="numberprgn" header="Incident No." width="80">
      <cfgridcolumn name="open_time" header="Opened" width="78" mask="mm/dd/yyyy">
      <cfgridcolumn name="status" header="Status" width="70">
      <cfgridcolumn name="full_name" header="Assigned To" width="120">
      ... more plus submits...
      The post page just CFDUMPs form variables. I can call up the form, click on the first row, click on submit, which opens a new window, and the "tickets" variable, the grid, is an empty string. I can close the window, go back to the form, click on the second row, click submit, and it works fine, showing selected row fields.
      I even have a Captivate screen capture of this behavior at http://www.larimer.org/temp/cfgrid2.htm . Is there some attribute I'm missing? Some behavior I'm not aware of? Is this a bug?
