7 Replies Latest reply on Dec 9, 2010 12:58 PM by Redade
    Updating progress bar manually doesnt show
    Flex-dude
      I would like to attach a progress bar to a long running function to indicate progress using code similar to the code below but the progress bar graphic only updates at the conclusion of the function call.
      Can anyone show me the correct way to get the progressBar to update while the function runs.
      The sample code simply makes the progressbar visible and then loops over a large number and updates the progressBar as each % of the loop is completed.
      When I run this code the progressBar does not display onscreen until the function has completed but with the correct 100% message showing.
        • 1. Re: Updating progress bar manually doesnt show
          flexstone
          I struggled with this problem too and created a CustomEvent "progressMadeEvent" to solve the problem
          package com.alQemy
          import flash.events.Event;
          public class progressMadeEvent extends Event
          public function progressMadeEvent(type:String,increment:int,max:int)
          super(type)
          this.max = max;
          this.increment = increment;
          // Define static constant.
          public static const incrementChange:String = "incrementChange";
          // Define a public variable to hold the state of the enable property.
          public var increment:int;
          public var max:int;
          override public function clone():Event{
          return new progressMadeEvent(incrementChange,increment,max)
          When you launch your process you need to include a line to create an eventListener on the application that will update the progressBar
          thisApp.addEventListener("incrementChange",updateProgress)
          private function updateProgress(event):void{
          pBar.setProgress(event.increment,event.max)
          pBar.label = int((event.increment/event.max)*100)+"% complete"
          trace(event.increment+'-'+event.max)
          if(event.increment==event.max){
          //remove listener when complete
          thisApp.removeEventListener("incrementChange",updateProgress)
          this.invalidateProperties()
          pBar.invalidateProperties()
          Now in the loop of your lengthy process insert these lines to increment the process and dispatch the CustomEvent that your ProgressBar is listening too....
          // incr is the current iteration of your loop
          // mx is the total interations of your loop
          thisApp.dispatchEvent(new progressMadeEvent("incrementChange",incr,mx))
          • 2. Re: Updating progress bar manually doesnt show
            seRajan
            <mx:WindowedApplication xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
            <mx:Script>
            <![CDATA[
            import mx.controls.Alert;
            private var tim:Timer = new Timer(100);
            public function init():void
            tim.addEventListener(TimerEvent.TIMER, progress);
            private function progress(evt:Event):void
            progressBar.setProgress(tim.currentCount, 100);
            if(tim.currentCount == 100)
            tim.stop();
            public function updateProgress():void
            tim.reset();
            tim.start();
            progressBar.visible = true;
            </mx:Script>
            <mx:ProgressBar x="10" y="10" id="progressBar" mode="manual" visible="false" />
            <mx:Button x="10" y="40" label="Button" id="theButton" click="updateProgress()"/>
            </mx:WindowedApplication>
            use this
            For loop is not fit for this concept
            - Rajan
            • 3. Re: Updating progress bar manually doesnt show
              Level 7
              "Flex-dude" <webforumsuser@macromedia.com> wrote in message
              news:gk14os$5un$1@forums.macromedia.com...
              >indicate
              > only
              > the
              > function runs.
              > completed.
              Here's one approach:
              http://blog.paranoidferret.com/index.php/2007/12/11/flex-tutorial-an-asynchronous-jpeg-enc oder/
              • 4. Re: Updating progress bar manually doesnt show
                Flex-dude Level 1
                Thanks all for the prompt replies.
                flexstone, I had thought it would be something like that - nice one .
                Thanks for saving much time wasteage and head scratching.
                • 5. Re: Updating progress bar manually doesnt show
                  Redade
                  I did write all the code as you said but my applicaiton doesnt come into processProgress function...
                  here is what i did;
                  //this is my class
                      public class progressMade extends Event
                          public function progressMade(type:String,increment:int,max:int)
                              super(type)
                              this.max = max;
                          public var max:int;
                              return new progressMade(incrementChange,increment,max)
                  //this is my function
                              public function processProgress(event:progressMade):void
                                  //imageLoadingProgressBar.setProgress((frameNum + 1),numImages);
                                  imageLoadingProgressBar.setProgress(event.increment,event.max);
                                  imageLoadingProgressBar.label = "Loaded " +(event.increment + 1) + " of " + event.max;
                                  //this.removeEventListener("incrementChange",processProgress);
                                  //this.invalidateProperties();
                  //this is how i call it in loop
                  this.dispatchEvent(new progressMade("processProgress",frameNum,totalNum));
                  //this is how i add listener to applicaiton
                  application.addEventListener("incrementChange",processProgress);
                  never come into processProgressFunction....
                  • 7. Re: Updating progress bar manually doesnt show
                    Redade Level 1
                    That example is not working and i need to update the progress bar in a for
                    loop. So i tried your sample code.
                    Thank you.
                    2010/12/9 Peter deHaan (Adobe) <forums@adobe.com>
                    There is a simple manual ProgressBar example at
                    http://blog.flexexamples.com/2008/02/16/setting-the-value-of-a-flex-progress-bar/
                    Peter
