3 Replies Latest reply on Sep 11, 2006 11:08 AM by Newsgroup_User
    Help with Operators
    Anim8steve
      Currently working on a project were I need to assign a series of random options (members) a value, once selected by the user these values need to be added together and a total needs to be given and displayed on screen. So I need help assigning all the members a value and then adding them together also displaying the total.
        • 1. Re: Help with Operators
          Level 7
          The simpest possible thing is to use each member's number. As each
          sprite is selected, just add the member number to the current value of a
          global variable. For instance:
          global newTotal
          property thisSprite
          property thisMemberNumber
          on beginSprite me
          thisSprite = me.spriteNum
          thisMemberNumber = sprite(thisSprite).memberNum
          end
          on mouseUp me
          newTotal = newTotal + thisMemberNumber
          end
          Then you can access the value of newTotal anywhere in the movie where
          you need to use it.
          Rob
          _______
          Rob Dillon
          Adobe Community Expert
          http://www.ddg-designs.com
          412-243-9119
          http://www.macromedia.com/software/trial/
          • 2. Re: Help with Operators
            Anim8steve Level 1
            Thanks Rob for the quick response,
            One more Question
            "how do I access the value of the newTotal on the same screen as the selected options?" for instance could the value been shown in a field somewhere on the same screen as the options so that the participant can check their own score?
            • 3. Re: Help with Operators
              Level 7
              Place your text or field member on the stage and add the second line to
              the mouseUp function. Change the name to suit your needs.
              global newTotal
              property thisSprite
              on beginSprite me
              end
              on mouseUp me
              member("show Total").text = string(newTotal)
              end
              Rob
              _______
              Rob Dillon
              412-243-9119
