This content has been marked as final.
Show 10 replies
1. Re: Preserving Single Quotes
murpg Sep 27, 2006 10:00 AM (in response to Inkfast)Try something like this. #Replace(key,"'","’")# -
2. Re: Preserving Single Quotes
azadisaryev Sep 27, 2006 10:05 AM (in response to Inkfast)i think your error is due to a wrong sql statement first of all... you have to use ZipCode = before each value you are checking fo, not just once like you do.
so you have to change
<cfset Caller.passedreturneddata = Caller.passedreturneddata & "'#mystruct.zipcode[x]#' or ">
to
<cfset Caller.passedreturneddata = Caller.passedreturneddata & "'#mystruct.zipcode[x]#' or ZipCode=">
on the other hand, why don't you change your Caller.passedreturneddata to a comma-delimited list and then use "... AND ZipCode IN '#Caller.passedreturneddata#' instead? -
3. Re: Preserving Single Quotes
Dan Bracuk Sep 27, 2006 10:41 AM (in response to Inkfast)use the preservesinglequotes function. -
4. Re: Preserving Single Quotes
Inkfast Sep 27, 2006 3:23 PM (in response to Dan Bracuk)Originally it was a comma delimited list, but frankly I wasn't sure how work with it that way. So if I understand you that would be...
<cfquery datasource="normmy_denver" name="events">
Select *
From Calendar2
Where fee = No
And Category = #form.category#
And Subcategory = #form.subcategory#
And ZipCode IN '#Caller.passedreturneddata#'
Order by date, time
<cfquery> -
5. Re: Preserving Single Quotes
azadisaryev Sep 27, 2006 4:06 PM (in response to Inkfast)yes, as long as your Caller.passedreturneddata is a comma-delimited list, you can use it like that. -
6. Re: Preserving Single Quotes
Stefan_K. Sep 28, 2006 2:09 AM (in response to Inkfast)quote:
Select *
From Calendar2
Where fee = No
And ZipCode IN '# ListQualify(Caller.passedreturneddata, "'")#'
Order by date, time
<cfquery>
7. Re: Preserving Single Quotes
Inkfast Sep 28, 2006 10:32 AM (in response to Inkfast)That worked for the single quotes, but I've never seen this error before. Not finding anything in Google either.
Error Executing Database Query.
[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] In operator without () in query expression 'fee = No And Category = Horoscope And Subcategory = Horoscope3 And ZipCode IN
Select * From Calendar2 Where fee = No And Category = Horoscope And Subcategory = Horoscope3 And ZipCode IN ''80212',' 80212',' 80212',' 80034',' 80214',' 80214',' 80214',' 80214',' 80211',' 80033',' 80033',' 80033',' 80001',' 80002',' 80002',' 80002',' 80204',' 80295',' 80257',' 80266',' 80266',' 80248',' 80217',' 80265',' 80292',' 80215',' 80215',' 80215',' 80255',' '' Order by date, time -
8. Re: Preserving Single Quotes
Dan Bracuk Sep 28, 2006 10:54 AM (in response to Inkfast)You need parentheses when using the keyword IN in sql. It's right there in your error message, didn't you read it?
You should also know that you have changed your logic from what you were initially attempting to do. -
9. Re: Preserving Single Quotes
Inkfast Sep 28, 2006 11:35 AM (in response to Dan Bracuk)I read it, I didn't understand it. -
10. Re: Preserving Single Quotes
Inkfast Sep 29, 2006 9:38 AM (in response to Inkfast)I got it to work with a variation of what you guys wrote...
And ZipCode IN (#PreserveSingleQuotes (passedreturneddata)#)
Thanks for all the help!
D.
