1 2 Previous Next 53 Replies Latest reply on Sep 30, 2006 4:57 PM by Newsgroup_User
    Swap MovieClips
    GellyBean
      Scenario: I have 3 pictures (MC) that I would like to have played one on top of the other.
      My problem is that when the last MC is played, the first one appears abruptly, rather than appearing on top of the last MC played.
      Which is the script to have the first MC play one on top of the last, constantly?
        • 1. Re: Swap MovieClips
          Level 7
          GellyBean,
          Okay.
          > MC played.
          I'm not sure what you mean by "abruptly" in this context, I guess. Are
          you talking about an issue with which image is on top? Abruptly could be
          interpreted as "suddenly," which doesn't intrinsically have anything to do
          with layering -- see what I mean? Just trying to understand. :)
          Well, there's a method of the MovieClip class called
          MovieClip.swapDepths(). That seems to match the subject line of your post.
          Is that what you're after?
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Swap MovieClips
            GellyBean Level 1
            Mr Stiller,
            I think that's exactly what I want. I would like to put those 3+ pictures (wiht effect) in one MC and swap each one on top of the other.
            • 3. Re: Swap MovieClips
              Level 7
              GellyBean,
              >> subject line of your post. Is that what you're after?
              > top of the other.
              That may be it, then. :) Note in the documentation that
              MovieClip.swapDepths() can be used two ways: one allows you to swap the
              depth of one movie clip with another; the other allows you to set the depth
              of a movie clip using a number.
              So you could either keep swapping clips, as desired, or use something
              like MovieClip.getNextHighestDepth(), which returns a number.
              David Stiller
              • 4. Re: Swap MovieClips
                GellyBean Level 1
                So... How can I do it ???
                • 5. Re: Swap MovieClips
                  Level 7
                  GellyBean,
                  Have you looked up the MovieClip.swapDepths() method in the ActionScript
                  2.0 Language Reference? ;)
                  David Stiller
                  • 6. Re: Swap MovieClips
                    GellyBean Level 1
                    Thank you David,
                    I see the function of swap depths and I think that is not what I am really looking for.
                    I also think that, because I have not explained myself well, as I really don't want to click the images in order to see them.
                    The images come up by themselves.
                    Inside my flash movie, I have a rotating banner with 3 pics inside (each picture appears with a mask effect). What I mean, is that each picture is a MC. I would like it, that each picture appears, one on top of the other, every X amount of time.
                    • 7. Re: Swap MovieClips
                      Level 7
                      GellyBean,
                      Okay.
                      > to see them.
                      That's fine. None of these functions require buttons. :)
                      Okay.
                      I think I can picture that -- of course, what I envision may be
                      different from what it actually is.
                      In order for clipA to appear on top of clipB, clipA must be higher than
                      clipB. If it isn't already, the only way to arrange that via ActionScript
                      is with the MovieClip.swapDepths() method.
                      David Stiller
                      • 8. Re: Swap MovieClips
                        GellyBean Level 1
                        I made a MC with two layers (one 4 actions the other for pictures)
                        The code that I used is this, but it is not working*:
                        pic1_mc.play();
                        function () {
                        if (this.getDepth()<pic2_mc.getDepth()) {
                        this.swapDepths(pic2_mc);
                        pic2_mc.play();
                        function () {
                        if (this.getDepth()<pic1_mc.getDepth()) {
                        this.swapDepths(pic1_mc);
                        *(I'm sorry if I'm annoying you but I'm new in this stuff)
                        • 9. Re: Swap MovieClips
                          Level 7
                          GellyBean,
                          > other for pictures) The code that I used is this,
                          > pic1_mc.play();
                          > function () {
                          In the first line, you're telling a movie clip whose instance name is
                          pic1_mc to play. Where is this code? Is this in the timeline of pic1_mc?
                          If so, consider the "point of view" of this ActionScript. If you're already
                          inside pic1_mc, this code is going to look for an object named pic1_mc ...
                          are you going to find it? It's interesting to me that you used "this" in
                          the function, because "this" refers to the object or timeline it's in.
                          Depending on your circumstances, "this" might refers to pic1_mc; it might
                          not.
                          You can use the trace() function to kind of help you "see under the
                          hood." Before you do anything else, you'll have to actually *run* the
                          function. You're written one, but you aren't calling it anywhere.
                          function test() {
                          trace("Hi there");
                          On its own, that doesn't do anything. To call this function, type
                          test() ... make sense? You don't have to type it right away. In you might,
                          for example, call the test() function from inside a button, whenever the
                          user gets around to clicking ... or you might call the test() function in a
                          later frame of that timeline -- or any other timeline or object that can
                          path to the timeline in which the function was written.
                          e.g. if the function is written inside clipA, you can call it from the
                          main timeline -- assuming clipA is in the main timeline -- like this ...
                          clipA.test();
                          If this were my project, I'd probably put all the ActionScript in frames
                          of the main timeline, rather than inside the clips themselves. Just give
                          each clip an instance name and then call each by name from the main
                          timeline, telling it what to do -- based on the properties, methods, and
                          events described in that object's (in this case, the MovieClip) class.
                          David Stiller
                          • 10. Re: Swap MovieClips
                            Level 7
                            GellyBean,
                            > pic1_mc.play();
                            > function () {
                            not.
                            function test() {
                            trace("Hi there");
                            clipA.test();
                            David Stiller
                            • 11. Re: Swap MovieClips
                              Level 7
                              GellyBean,
                              > pic1_mc.play();
                              > function () {
                              not.
                              function test() {
                              trace("Hi there");
                              clipA.test();
                              David Stiller
                              • 12. Re: Swap MovieClips
                                Level 7
                                GellyBean,
                                > pic1_mc.play();
                                > function () {
                                not.
                                function test() {
                                trace("Hi there");
                                clipA.test();
                                David Stiller
                                • 13. Re: Swap MovieClips
                                  Level 7
                                  GellyBean,
                                  > pic1_mc.play();
                                  > function () {
                                  not.
                                  function test() {
                                  trace("Hi there");
                                  clipA.test();
                                  David Stiller
                                  • 14. Re: Swap MovieClips
                                    Level 7
                                    GellyBean,
                                    > pic1_mc.play();
                                    > function () {
                                    not.
                                    function test() {
                                    trace("Hi there");
                                    clipA.test();
                                    David Stiller
                                    • 15. Re: Swap MovieClips
                                      Level 7
                                      GellyBean,
                                      > pic1_mc.play();
                                      > function () {
                                      not.
                                      function test() {
                                      trace("Hi there");
                                      clipA.test();
                                      David Stiller
                                      • 16. Re: Swap MovieClips
                                        Level 7
                                        GellyBean,
                                        > pic1_mc.play();
                                        > function () {
                                        not.
                                        function test() {
                                        trace("Hi there");
                                        clipA.test();
                                        David Stiller
                                        • 17. Re: Swap MovieClips
                                          Level 7
                                          GellyBean,
                                          > pic1_mc.play();
                                          > function () {
                                          not.
                                          function test() {
                                          trace("Hi there");
                                          clipA.test();
                                          David Stiller
                                          • 18. Re: Swap MovieClips
                                            Level 7
                                            GellyBean,
                                            > pic1_mc.play();
                                            > function () {
                                            not.
                                            function test() {
                                            trace("Hi there");
                                            clipA.test();
                                            David Stiller
                                            • 19. Re: Swap MovieClips
                                              Level 7
                                              GellyBean,
                                              > pic1_mc.play();
                                              > function () {
                                              not.
                                              function test() {
                                              trace("Hi there");
                                              clipA.test();
                                              David Stiller
                                              • 20. Re: Swap MovieClips
                                                Level 7
                                                GellyBean,
                                                > pic1_mc.play();
                                                > function () {
                                                not.
                                                function test() {
                                                trace("Hi there");
                                                clipA.test();
                                                David Stiller
                                                • 21. Re: Swap MovieClips
                                                  Level 7
                                                  GellyBean,
                                                  > pic1_mc.play();
                                                  > function () {
                                                  not.
                                                  function test() {
                                                  trace("Hi there");
                                                  clipA.test();
                                                  David Stiller
                                                  • 22. Re: Swap MovieClips
                                                    Level 7
                                                    GellyBean,
                                                    > pic1_mc.play();
                                                    > function () {
                                                    not.
                                                    function test() {
                                                    trace("Hi there");
                                                    clipA.test();
                                                    David Stiller
                                                    • 23. Re: Swap MovieClips
                                                      Level 7
                                                      GellyBean,
                                                      > pic1_mc.play();
                                                      > function () {
                                                      not.
                                                      function test() {
                                                      trace("Hi there");
                                                      clipA.test();
                                                      David Stiller
                                                      • 24. Re: Swap MovieClips
                                                        Level 7
                                                        GellyBean,
                                                        > pic1_mc.play();
                                                        > function () {
                                                        not.
                                                        function test() {
                                                        trace("Hi there");
                                                        clipA.test();
                                                        David Stiller
                                                        • 25. Re: Swap MovieClips
                                                          Level 7
                                                          GellyBean,
                                                          > pic1_mc.play();
                                                          > function () {
                                                          not.
                                                          function test() {
                                                          trace("Hi there");
                                                          clipA.test();
                                                          David Stiller
                                                          • 26. Re: Swap MovieClips
                                                            Level 7
                                                            GellyBean,
                                                            > pic1_mc.play();
                                                            > function () {
                                                            not.
                                                            function test() {
                                                            trace("Hi there");
                                                            clipA.test();
                                                            David Stiller
                                                            • 27. Re: Swap MovieClips
                                                              Level 7
                                                              GellyBean,
                                                              > pic1_mc.play();
                                                              > function () {
                                                              not.
                                                              function test() {
                                                              trace("Hi there");
                                                              clipA.test();
                                                              David Stiller
                                                              • 28. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 29. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 30. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 31. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 32. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 33. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 34. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 35. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 36. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 37. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 38. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        • 39. Re: Swap MovieClips
        Level 7
        GellyBean,
        > pic1_mc.play();
        > function () {
        not.
        function test() {
        trace("Hi there");
        clipA.test();
        David Stiller
        1 2 Previous Next
