1 2 Previous Next 51 Replies Latest reply on Oct 2, 2006 12:54 PM by kenewing
    Embedding a series of stop points in a timeline
    kenewing
      I have Flash 8 running on Windows XP. I’m just learning to use it. I’ve been through the training from Total Training and I’ve completed a successful project. Now I want to do something more with the project and I don’t know how to proceed.
      I want to embed a series of checkpoints in the timeline. Then I want to create a button called “Step” that, when clicked, will play the movie up to the next checkpoint, then stop. Click “Step” again and you resume the movie at that point and stop at the next checkpoint. This will let me step through the movie and have it pause it at predetermined points.
      Thanks for any input.
        • 1. Re: Embedding a series of stop points in a timeline
          Level 7
          kenewing,
          > Then I want to create a button called ?Step? that, when
          > then stop.
          Sounds like you may want to put a frame script at each of these
          checkpoints that simply says stop();. Have your button tell the main
          timeline to play(); -- that should do it. The main timeline is a movie
          clip, like any movie clip symbol, so it will continue to play until told to
          stop.
          Does that make sense?
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Embedding a series of stop points in a timeline
            kenewing Level 1
            This works partially. I can embed a stop() at each checkpoint in the timeline, then attach a play() script to the Step button. I can then step through the timeline as desired. The problem is that the Flash file becomes either/or rather than both/and. I can set up the movie to play continuously, OR set it up to step manually, but I can't do both.
            Ideally, I want to have two buttons: one that plays the whole timeline without pauses, and a different one that lets me step through the timeline manually.
            Further ideas?
            • 3. Re: Embedding a series of stop points in a timeline
              kenewing Level 1
              Addendum: What I imagine doing is putting some kind of marker at selected frames, then scripting the Step button to do something like "play until (marker), then stop." But I don't know if such a thing can be done in Flash.
              • 4. Re: Embedding a series of stop points in a timeline
                Level 7
                kenewing,
                I'm with ya.
                > can't do both.
                Sure you can. :)
                Okay, sounds like a good use for a variable.
                > Further ideas?
                Create a variable in frame 1.
                var doPausing:Boolean = false;
                Then check that variable in later frames to see if you should do the
                pausing or not. For example, where you might currently have a stop() action
                on frame 20, change it to this ...
                if (doPausing == true) {
                stop();
                Or, shorthand ...
                if (doPausing) {
                stop();
                It just means that the main timeline will only obey the stop() if that
                variable's value is true. Use your buttons to set it true or false.
                // Play button
                btnPlay.onRelease = function() {
                doPausing = false;
                gotoAndPlay( whatever frame to start on );
                // Play with pauses
                btnPlayWithPauses.onRelease = function() {
                doPausing = true;
                David Stiller
                • 5. Re: Embedding a series of stop points in a timeline
                  kenewing Level 1
                  All makes sense. I inserted the action scripts as suggested adapting all the names to suit. When I generate the swf file, I get the following two error messages:
                  **Error** Scene=Scene 1, layer=layer_name, frame=1:Line 1: Statement must appear within on handler
                  btnStep.onRelease = function() {
                  I admit that I'm inexperienced in programming. Can you discern from this where the error comes from?
                  • 6. Re: Embedding a series of stop points in a timeline
                    Level 7
                    kenewing,
                    > All makes sense.
                    Cool.
                    That means you're pasting the code directly on the button, rather than
                    in the main timeline. If you're pasting directly to the button, you need to
                    put your code within an on() or onClipEvent() handler. That's how things
                    were done back in Flash 5, but the current best practices recommendation is
                    that you put your code in a layer of the main timeline. That's the reason
                    for instance names on your movie clips: the code sits in a timeline and
                    calls the desired clips by name. When code is in an on() handler, it's
                    directly attached, so instance names aren't necessary.
                    Here are some thoughts on the matter.
                    http://www.quip.net/blog/2006/flash/museum-pieces-on-and-onclipevent
                    David Stiller
                    • 7. Re: Embedding a series of stop points in a timeline
                      Level 7
                      kenewing,
                      > All makes sense.
                      Cool.
                      David Stiller
                      • 8. Re: Embedding a series of stop points in a timeline
                        Level 7
                        kenewing,
                        > All makes sense.
                        Cool.
                        David Stiller
                        • 9. Re: Embedding a series of stop points in a timeline
                          Level 7
                          kenewing,
                          > All makes sense.
                          Cool.
                          David Stiller
                          • 10. Re: Embedding a series of stop points in a timeline
                            kenewing Level 1
                            OK, I think we're homing in on it. I think I've got things working except for the Step function. I moved the scripts from the button to the frame as you suggested. But the Step button doesn't work yet. Below is the relevant code in that ActionScript window. In frame 1:
                            doPausing = true;
                            gotoAndPlay( startFrame );
                            At each pause point in the timeline I have the following lines embedded in a frame:
                            stop();
                            Here's the tripwire: how do I enter a relative value for startFrame in frame 1? After each pause, I need the Step button to execute a play() starting with the next frame in the timeline.
                            Make sense? Thanks for all the help so far.
                            • 11. Re: Embedding a series of stop points in a timeline
                              Level 7
                              kenewing,
                              > All makes sense.
                              Cool.
                              David Stiller
                              • 12. Re: Embedding a series of stop points in a timeline
                                Level 7
                                kenewing,
                                > All makes sense.
                                Cool.
                                David Stiller
                                • 13. Re: Embedding a series of stop points in a timeline
                                  Level 7
                                  kenewing,
                                  > All makes sense.
                                  Cool.
                                  David Stiller
                                  • 14. Re: Embedding a series of stop points in a timeline
                                    Level 7
                                    kenewing,
                                    > All makes sense.
                                    Cool.
                                    David Stiller
                                    • 15. Re: Embedding a series of stop points in a timeline
                                      Level 7
                                      kenewing,
                                      > All makes sense.
                                      Cool.
                                      David Stiller
                                      • 16. Re: Embedding a series of stop points in a timeline
                                        Level 7
                                        kenewing,
                                        > All makes sense.
                                        Cool.
                                        David Stiller
                                        • 17. Re: Embedding a series of stop points in a timeline
                                          Level 7
                                          kenewing,
                                          > All makes sense.
                                          Cool.
                                          David Stiller
                                          • 18. Re: Embedding a series of stop points in a timeline
                                            Level 7
                                            kenewing,
                                            > All makes sense.
                                            Cool.
                                            David Stiller
                                            • 19. Re: Embedding a series of stop points in a timeline
                                              Level 7
                                              kenewing,
                                              > All makes sense.
                                              Cool.
                                              David Stiller
                                              • 20. Re: Embedding a series of stop points in a timeline
                                                Level 7
                                                kenewing,
                                                > All makes sense.
                                                Cool.
                                                David Stiller
                                                • 21. Re: Embedding a series of stop points in a timeline
                                                  Level 7
                                                  kenewing,
                                                  > All makes sense.
                                                  Cool.
                                                  David Stiller
                                                  • 22. Re: Embedding a series of stop points in a timeline
                                                    Level 7
                                                    kenewing,
                                                    > All makes sense.
                                                    Cool.
                                                    David Stiller
                                                    • 23. Re: Embedding a series of stop points in a timeline
                                                      Level 7
                                                      kenewing,
                                                      > All makes sense.
                                                      Cool.
                                                      David Stiller
                                                      • 24. Re: Embedding a series of stop points in a timeline
                                                        Level 7
                                                        kenewing,
                                                        > All makes sense.
                                                        Cool.
                                                        David Stiller
                                                        • 25. Re: Embedding a series of stop points in a timeline
                                                          Level 7
                                                          kenewing,
                                                          > All makes sense.
                                                          Cool.
                                                          David Stiller
                                                          • 26. Re: Embedding a series of stop points in a timeline
                                                            Level 7
                                                            kenewing,
                                                            > All makes sense.
                                                            Cool.
                                                            David Stiller
                                                            • 27. Re: Embedding a series of stop points in a timeline
                                                              Level 7
                                                              kenewing,
                                                              > All makes sense.
                                                              Cool.
                                                              David Stiller
                                                              • 28. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 29. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 30. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 31. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 32. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 33. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 34. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 35. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 36. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 37. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 38. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        • 39. Re: Embedding a series of stop points in a timeline
        Level 7
        kenewing,
        > All makes sense.
        Cool.
        David Stiller
        1 2 Previous Next
