12 Replies Latest reply on Mar 24, 2009 12:22 AM by JavaIsLife
    Fireworks pop-up menu
    Primal69
      I've made a simple menu .png with a pop-up sub menu in fireworks and when I test it in a browser it works fine. When I load all the files on my server and embed the html file on a page, when tested in a browser the menu's there but the pop-up sub menu doesn't work. I've tried starting from scratch several times but still no good. All the slices and images are in the correct directory... it''s really frustrating! Can anyone please help?
      Rick
        • 1. Re: Fireworks pop-up menu
          Level 7
          Which FW? Can you post a link to the page?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "Primal69" <webforumsuser@macromedia.com> wrote in message
          news:gk4khr$qe$1@forums.macromedia.com...
          > I
          > and
          > but
          > Thanks
          > Rick
          • 2. Re: Fireworks pop-up menu
            Primal69 Level 1
            yes. the url is http://www.phatsnaps.com/test.html
            and there should be a drop down sub menu to 'room 1' & 'room 2'.
            • 3. Re: Fireworks pop-up menu
              Level 7
              None of the required javascript is in the head of the page - that's why your
              menu is failing.
              Do yourself a huge favor. Move away from this awkward menu implementation.
              Check the uberlink and MacFly tutorials at PVII -
              and the Navbar tutorial/articles at Thierry's place
              http://tjkdesign.com/articles/dropdown/
              Or this one (more recent article):
              http://tjkdesign.com/articles/Pure_CSS_Dropdown_Menus.asp
              Or to get it done fast, go here -
              http://www.projectseven.com/tutorials/navigation/auto_hide/index.htm
              news:gk4u17$c52$1@forums.macromedia.com...
              > Thanks
              • 4. Re: Fireworks pop-up menu
                Primal69 Level 1
                thanks but that's WAY too complex for me!!
                • 5. Re: Fireworks pop-up menu
                  Level 7
                  You'll think the same thing as you work on the menu system you have chosen.
                  I suggest you go to PVII ( http://www.projectseven.com/) and purchase one of
                  their menu systems (PopMenuMagic2 is worth every dime).
                  news:gk5305$ic9$1@forums.macromedia.com...
                  • 6. Re: Fireworks pop-up menu
                    Primal69 Level 1
                    Yes, thanks, it looks really good. The problem is, I'm doing this for a school project and a working Fireworks menu with sub menus is required...
                    • 7. Re: Fireworks pop-up menu
                      Level 7
                      Then I suggest you try again. The menu is not working because the required
                      javascript is not on the page. Please make sure when you place the menu in
                      the DW page, you use INSERT | Image Objects > Fireworks HTML.
                      news:gk70j7$84e$1@forums.macromedia.com...
                      • 8. Re: Fireworks pop-up menu
                        Primal69 Level 1
                        yes, thanks, I have. Numerous times. Can't understand it..!
                        • 9. Re: Fireworks pop-up menu
                          Level 7
                          Try it on a dummy (blank) page. Look at the code. See if you have
                          javascript inserted in the head of the page. Do you?
                          news:gk7u94$hjs$1@forums.macromedia.com...
                          • 10. Re: Fireworks pop-up menu
                            JavaIsLife
                            Hi Folks,
                            I have this question. I am using Studio 8. I did an interface with fireworks, complete with popupmenus and all. I than exported the .png file. I choose the option 'HTML and images. The export worked fine and I can load the page in a browser and it looks fine and the pop menus work fine.
                            In Dreamweaver, I saved the exported file as a template. I created an editable region. Just for testing sake, I previewed the 'template' in IE and it looked and worked fine. Now the problems begin when I begin to create pages off this template. The pages look just fine while in dremweaver, but when I preview them, what I see is 'x' wherever I was supposed to see images. The 'x' is the type when we see a broken link for an image, but everyhing is in the same folder, and the .dwt worked just fine, so I dont know why this is happening? Can anyone throw some light into this? Thank you.
                            • 11. Re: Fireworks pop-up menu
                              Level 7
                              Please read this carefully -
                              http://www.losingfight.com/blog/2006/08/11/the-sordid-tale-of-mm_menufw_menujs/
                              You may want to drop back and punt on this menu.
                              "JavaIsLife" <webforumsuser@macromedia.com> wrote in message
                              news:gputvb$cj1$1@forums.macromedia.com...
                              > Hi Folks,
                              > fireworks,
                              > the
                              > a
                              > editable
                              > looked
                              > this
                              > the
                              > happening?
                              • 12. Re: Fireworks pop-up menu
                                JavaIsLife Level 1
                                Hi Murray ,
                                Thank you for the reply. I just noticed something else. Let's forget menus and drop down lists for a moment. I defined a site, and in the 'Links relative to' option, I selected 'Site root' and I got the message, I need to provide a valid HTTP address for all site relative links to work correctly message, I proceeded anyway. So what happens is that this single html page has got one image sitting in it. When I preview the page, I get the 'x' inplace of the image. I went back to site manage to change the 'Links relative to' setting to Document, and the problem still persists. I am not sure why. The code seems fine to me. Any idea why this happens?
