4 Replies Latest reply on Jan 7, 2009 7:43 PM by Newsgroup_User
    ADOBE - Forum search is broken
    Ansury Level 3
      The web site you are accessing has experienced an unexpected error.
      Please contact the website administrator.
      The following information is meant for the website developer for debugging purposes.
      Error Occurred While Processing Request
      Variable FTVAR_RESULTTYPE is undefined.
      Resources:
      Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option.
      Check the ColdFusion documentation to verify that you are using the correct syntax.
      Search the Knowledge Base to find a solution to your problem.
      Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; InfoPath.1)
      Remote Address 10.172.32.23
      Referrer http://www.adobe.com/cfusion/webforums/forum/categories.cfm?forumid=60&catid=585&entercat= y
      Date/Time 07-Jan-09 10:22 AM
