3 Replies Latest reply on Sep 26, 2006 11:47 PM by Newsgroup_User
    fonts to library
    Grmfl
      I'm told that all fonts used in my animation need to be in the library, but I don't know how to add them. I've tried Import under the file menu but it doesn't work.
      Thanks for helping my clueless self....
        • 1. Re: fonts to library
          Level 7
          that's simply not true - flash uses your system fonts - and they do not need to be in your library -
          there are many ways to use fonts in flash - but whoever told you that is wrong unless they were
          referring to embedding fonts with dynamic text fields.
          --> **Adobe Certified Expert**
          --> www.mudbubble.com
          --> www.keyframer.com
          > doesn't work.
          • 2. Re: fonts to library
            Rafiq Elmansy, AEL, ACP Level 2
            You can add fonts to the library as following:
            1- open the Library option menu (the one on the top right of the Library panel) and choose new font
            2- Choose the fonts you like to add, name it and click Ok
            Hope this helps
            • 3. Re: fonts to library
              Level 7
              actually - i should ask - how are your fonts being used? perhaps they do - but youy mentioned
              animation - and most likely they are set to Static - if so, they are included in with the SWF upon
              export so they will render as intended.
              > doesn't work.
