4 Replies Latest reply on Jun 12, 2007 4:58 PM by jason_v2
    Creating charts in actionscript
    McDusty
      Im working on producing charts that can have a dynamic number of data series. Seems the best way to do this is to produce the charts in actionscript. I have it working so the chart displays as wanted. but can't find a way to apply my mxml gradient fills and effects in actionscript ....
      ie, this produced nice blue bars for my columns ....
      <mx:ColumnSeries yField="value" showDataEffect="{interpolate}">
      <mx:fill>
      <mx:LinearGradient>
      <mx:entries>
      <mx:Array>
      <mx:GradientEntry color="#C6D5DD" ratio="0" alpha="100"/>
      <mx:GradientEntry color="#336699" ratio="0.05" alpha="100"/>
      <mx:GradientEntry color="#24496D" ratio="0.95" alpha="100"/>
      <mx:GradientEntry color="#000000" ratio="1" alpha="100"/>
      </mx:Array>
      </mx:entries>
      </mx:LinearGradient>
      </mx:fill>
      </mx:ColumnSeries>
      in actionscript i can produce the ColumnSeries and the LinearGradients / GradientEntry, but can't see a way to connect the two.
      var colSeries:ColumnSeries = new ColumnSeries();
      colSeries.yField = "value";
      var linearGradient:LinearGradient = new LinearGradient();
      var gradientEntry:GradientEntry = new GradientEntry();
      var cG1 = new GradientEntry(0xC6D5DD,0,1);
      var cG2 = new GradientEntry(0x336699,0.05,1);
      var cG3 = new GradientEntry(0x24496D,0.95,1);
      var cG4 = new GradientEntry(0x000000,1,1);
      linearGradient.entries = [cG1, cG2, cG3, cG4];
      But how do i tell the ColumnSeries to use the LinearGradient in actionsctript?
      Also when trying to use the ColumnSeries.showDataEffect im greeted with "Error: Access of possibly undefined property showDataEffect through a reference with static type mx.charts.series:ColumnSeries" ... how can i set chart effects in actionscript?
      Any help would be greatly appreciated
      Regards
      Ash
        • 1. Creating charts in actionscript
          McDusty Level 1
          Rather embarrassingly i found the answer to one of my problems within 5 mins of asking this ... one can tell the ColumnSeries to use the LinearGradient with the setStyle funtion ...
          colSeries.setStyle("fill",linearGradient);
          However im still stuck on how to get my showDataEffect working in actionscript.
          • 2. Re: Creating charts in actionscript
            bolaughlin Level 1
            use setStyle for the effect as well. Assuming an effect you defined named "myInterpolate":
            colSeries.setStyle ("showDataEffect", myInterpolate);
            --Brian
            • 3. Re: Creating charts in actionscript
              McDusty Level 1
              Cheers Brian, that worked.
              Don't know why i didn't think of that. Was trying to attach an event listener to 'showData', and create my own seriesInterpolate, but to no avail.
              Cheers
              Ash
              • 4. Re: Creating charts in actionscript
                jason_v2
                Hey guys,
                I tried the same kinda thing but with no success. I have a pie chart where I want to specify a gradient fill for each individual slice (kind of like the Flex Dashboard example), except, I want to do it in Actionscript.
                var pieChart:PieChart = new PieChart;
                var series:PieSeries = new PieSeries;
                /*A bunch of other stuff goes here styling/binding/etc*/
                var grad1:GradientEntry = new GradientEntry(0xC6D5DD,0.3);
                var grad2:GradientEntry = new GradientEntry(0x336699,0.3);
                var grad3:GradientEntry = new GradientEntry(0x24496D,0.3);
                var grad4:GradientEntry = new GradientEntry(0x000000,0.3);
                radialGradient.entries = [grad1,grad2,grad3,grad4];
                series.setStyle("fill", radialGradient);
                pieChart.series.push(series);
                Can anyone see anything blatantly wrong with this? Thanks!!
