7 Replies Latest reply on Sep 26, 2006 6:44 PM by Newsgroup_User
    How to get form upload value...?
    noijet
      Hi, I'd like to know how to get form upload value?
      I have my initial page, index.cfm that has a upload input box (named "fileToUpload")that submits to action.cfm. In action.cfm I tried to get the value of the input by doing <cfoutput>#form.fileToUpload#</cfoutput> but instead I got a string like ("E:\JRun4\servers\cfusion\SERVER-INF\temp\cfusion-war-tmp\neotmp5263.tmp"), I expected it to be the value that was in the upload input field (i.e. "E:\My Pictures\Flowers.jpg"). How do I get this?
      noijet
        • 1. Re: How to get form upload value...?
          Level 7
          1) Read the documentation about uploading files.
          2) You got what you should have got. ColdFusion does not get the file
          from the client, ie @ E:\\My Pictures\Flowers.jpg. When the form was
          submitted, the browser got the file and sent to the server as part of
          the response. The server then saved it in a temporary location as you
          noted @
          E:\JRun4\servers\cfusion\SERVER-INF\temp\cfusion-war-tmp\neotmp5263.tmp.
          3) To do something with this you will use at least a <cffile
          action="upload" ...> (see <cffile documentation). More logic is
          probably required, depending on what you want to do after that.
          • 2. Re: How to get form upload value...?
            noijet Level 1
            Hi Ian, thanks so much for your reply:
            I actually do the uploading this way(I have to save directly to DB):
            <cffile action="readbinary" file = "#FORM.fileUpload#" ...> and then I use this to insert into my DB. I can't do something like "#cffile.clientDirectory#" right? What else can I do?
            Thanks so much,
            noijet
            • 3. Re: How to get form upload value...?
              Level 7
              CFFILE.ServerFile
              http://livedocs.macromedia.com/coldfusion/7/htmldocs/00000192.htm#2712126
              CFFILE ACTION=Upload variables
              File variables are read-only. Use the CFFILE prefix to reference file
              variables; for example, CFFILE.ClientDirectory. The File prefix is
              deprecated in favor of the CFFILE prefix.
              CFFILE.AttemptedServerFile
              CFFILE.ClientFile
              CFFILE.ClientFileExt
              CFFILE.ClientFileName
              CFFILE.ContentSubType
              CFFILE.ContentType
              CFFILE.DateLastAccessed
              CFFILE.FileExisted
              CFFILE.FileSize
              CFFILE.FileWasAppended
              CFFILE.FileWasOverwritten
              CFFILE.FileWasRenamed
              CFFILE.FileWasSaved
              CFFILE.OldFileSize
              CFFILE.ServerDirectory
              CFFILE.ServerFile
              CFFILE.ServerFileExt
              CFFILE.ServerFileName
              CFFILE.TimeCreated
              CFFILE.TimeLastModified
              Ken Ford
              Adobe Community Expert
              "noijet" <webforumsuser@macromedia.com> wrote in message
              news:efc7gq$n7s$1@forums.macromedia.com...
              > the
              > I
              > "E:\My
              > Thanks,
              > noijet
              • 4. Re: How to get form upload value...?
                noijet Level 1
                Hi Ken, thanks so much for taking the time out to answer. I'm currently not doing <cffile action="upload...> instead I'm doing <cffile action="readbinary" file = "#FORM.fileUpload#" ...>, that is why I can't seem to get the variables, like CFFILE.ClientDirectory, CFFILE.ClientFile... Do you have any options for me?
                Thank you,
                noijet
                • 5. Re: How to get form upload value...?
                  Level 7
                  I think the file has to be on the server.
                  http://livedocs.macromedia.com/coldfusion/7/htmldocs/00000251.htm#3545306
                  cffile action = "readBinary"
                  Description
                  Reads a binary file (such as an executable or image file) on the server,
                  into a binary object parameter that you can use in the page.
                  Ken Ford
                  news:efcff2$31a$1@forums.macromedia.com...
                  > not
                  > action="readbinary"
                  > variables,
                  > for
                  > me?
                  > Thank you,
                  > noijet
                  • 6. Re: How to get form upload value...?
                    noijet Level 1
                    Hi Ken, thanks so much for your reply. I'm a cf newbie, so many thanks for your help. My project requires me to save image directly to sql server 2000. So I guess cffile action = "readBinary" is really my only option, do you have any ideas how I can get the client's directory b/c it gets converted to the neotemp#.tmp file? I was thinking about using javascript but the client may shut it off ?
                    Thanks so much Ken,
                    noijet
                    • 7. Re: How to get form upload value...?
                      Level 7
                      Upload the file first, then write it to the database:
                      http://www.forta.com/blog/index.cfm?mode=entry&entry=A61BC976-3048-80A9-EF7AE4D7D8F602B9
                      <cffile action = "upload" destination = "c:\CFusionMX\temp\" nameConflict =
                      "overwrite" fileField = "Form.FileToUpload" >
                      <cffile action = "readbinary" file = c:\CFusionMX\temp\#cffile.serverfile#"
                      variable = "binImage">
                      <cfquery name="PutPicture" datasource='#DSN#' username='#LoginDB#'
                      password='#PasswordDB#'>
                      insert into CFR_PICT (CFR,PICTURE)
                      values ('Cfr1' , <cfqueryparam cfsqltype="cf_sql_blob" value="#binImage#">)
                      </cfquery>
                      Ken Ford
                      news:efcj70$72q$1@forums.macromedia.com...
                      > for
                      > 2000.
                      > have
                      > the
                      > may
                      > shut it off ?
                      > Thanks so much Ken,
                      > noijet
