1 Reply Latest reply on Sep 29, 2006 3:26 AM by duckets
    Altering text field size
    jake_pomme
      I have 4 empty text fields whose text is set when questions are generated from a database. The size of the text fields when displayed on screen alter according to the amount of text they are to contain. Is there any of specifying exactly what size you want an empty text field cast member to be so that they all appear the same size. The only thing I have found is pageHeight but that can only be tested and not set.
        • 1. Re: Altering text field size
          duckets Level 1
          Select your text field sprite on stage. Go to the property inspector, choose the text/field tab (depending whether your member is a text or field member - they're different!). Then under framing, choose 'fixed'. You can then resize the vertical height of the sprite as you would any other.
          hope this helps!
          - Ben
