• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Robohelp HTML includes?
New Here ,
Sep 27, 2006 Sep 27, 2006
How can make make php type inludes in robohelp? Is it possible through templates or anything other feature in robohelp?
Views
591
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Sep 28, 2006 Sep 28, 2006
Hi Z33. Are you trying to import .PHP files into RH? You can't directly import .PHP files into RH however you can import .HTM files. It appears you can change the extensions of PHPs to HTMs but then things won't work (e.g. links, PHP tags). Check out this link found through Google for a start point.
Votes
Translate
Translate
Report
Report
New Here ,
No,
For example If i had a navigation bar in a seperate html file. Can robohelp include that html file at the top of every html file so that I could modify that 1 seperate html file and it would affect all the files that "include" that one file?
Sort of like templates but with more control as to where i include these pieces of html code.
Is this possible? What are alternatives that robohelp can do?
Basically, how can I generalize consistent code accross multiple pages , but not just at the header and footers like the templates allow, but rather anywhere in the html?
Votes
Translate
Translate
Report
Report
LEGEND ,
This sounds like what you want to do is use a frameset. The top portion of the frame would be your navigation bar and point to a single HTM file. Your frame would display two parts, the navigation bar and the other content. If you type framesets into RH help file index you'll find how to add these.
Votes
Translate
Translate
Report
Report
Engaged ,
Another way to do this is with an "inline frame." Unlike the frameset, this would not limit your included HTML file to a specific position in the view. One caveat - inline frames are difficult to use if your content changes size dramatically on editing.
Just another thought,
John
Votes
Translate
Translate
Report
Report
Advisor ,
LATEST
You could also use a document.write JavaScript function, but keep this in mind: the content displayed in either of these solutions will not appear in Printed Documentation output! Plan accordingly.
Leon
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
