1 Reply Latest reply on Aug 10, 2006 7:41 AM by kglad
      Please i need a code for password an section of my site.
      I did this based on code give on a forum but does not work.
      Where did i fail? This is the file:
        • 1. Re: Password
          first, you have duplicate frame labels. there should only be one frame labelled "wrong" and one labelled "vault". second, you should learn to use the trace() function.
          if you place trace(secret) to execute when your go button is pressed you'll see that your textfield is html-enabled. this is because you've specified a non-zero letter spacing.
          to remedy, change letter spacing to zero in the properties panel of your textfield (or with actionscript.)
