2 Replies Latest reply on Jan 21, 2009 9:12 AM by Newsgroup_User
    HTML code problem
    danoj22 Level 1
      Go to this page http://www.jeffcoflooring.com/new/. The click on prefinished floors and look at the icons, the click on finish products and look what happens to the icons. They drop to the bottom and distort the remainder of the page. This is the only page that this happens on. I have looked at everything in design view and css styles and cannot find anything different about this page. A few days ago it was fine, now this is happening. The only thing I can think of is maybe it is a code issue and I know nothing about code. If you think it is let me know and I will try to find the code and put it on here. Any help is appreciated. Thanks in advance.
        • 1. Re: HTML code problem
          Level 7
          Site is OK in Fx3. I see the problem in IE6. IE6 has a bug that doubles the
          declared margin if the element is floated and the margin is on the same side
          as the float. Your right-hand column has a float:right + a right margin.
          That is likely your problem.
          But you say, "I know nothing about code" so you may be dead in the water. DW
          expects you to know HTML & CSS and when you don't you are committing
          yourself to an endless series of problems like this one.
          Were I you, I would stop right now and study:
          1. HTML & CSS
          2. Web page design & construction
          3. Image editing for the web
          Only then will you be able to navigate all the potholes and deliver a
          quality website.
          Walt
          "danoj22" <webforumsuser@macromedia.com> wrote in message
          news:gl7itm$2rt$1@forums.macromedia.com...
          > prefinished
          > the
          > everything
          > this
          > can
          > here. Any
          • 2. Re: HTML code problem
            Level 7
            http://css-tricks.com/ie-css-bugs-thatll-get-you-every-time/
            Note: The Double Margin Bug
            Walt
            > prefinished
            > the
            > everything
            > this
            > can
            > here. Any
