2 Replies Latest reply on Jul 20, 2006 10:32 AM by Newsgroup_User
    Flex 2 : Possible bug in Slider
    stchavan
      I have been trying to restrict the thumbs of an HSlider from overlapping.
      Setting allowThumbOverlap to false did not work.
      I noticed that the ability of the thumbs to overlap is directly related to the maximum value allowed for the slider.
      Given below is an example for the same. I presume this must be a bug, since the documentation mentions
      nothing about this. If somebody can throw more light on this, it would be great.
      TestSlider.mxml
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns="*">
      <mx:HBox>
      <mx:Label text="Maximum 13" width="90"/>
      <mx:HSlider id="slider13" width="180" thumbCount="2" snapInterval="1" minimum="0" maximum="13" dataTipPlacement="bottom" />
      <mx:Label text="Thumbs overlap in both directions" width="300"/>
      </mx:HBox>
      <mx:HBox>
      <mx:Label text="Maximum 14" width="90"/>
      <mx:HSlider id="slider14" width="180" thumbCount="2" snapInterval="1" minimum="0" maximum="14" dataTipPlacement="bottom"/>
      <mx:Label text="Thumbs overlap from left to right" width="300"/>
      </mx:HBox>
      <mx:HBox>
      <mx:Label text="Maximum 15" width="90"/>
      <mx:HSlider id="slider15" width="180" thumbCount="2" snapInterval="1" minimum="0" maximum="15" dataTipPlacement="bottom"/>
      <mx:Label text="Thumbs do not overlap" width="300"/>
      </mx:HBox>
      </mx:Application>
      Regards!
      Santosh
        • 1. Re: Flex 2 : Possible bug in Slider
          Kishan M V Adobe Employee
          Hi Santosh,
          We are keeping track of this issue.
          • 2. Re: Flex 2 : Possible bug in Slider
            Level 7
            Santosh,
            This is indeed a bug. Thank you for bringing it to our attention. As a
            workaround, try using different values for the width property or don't
            specify a width at all.
            Jason Szeto
            Adobe Flex SDK Developer
            "stchavan" <webforumsuser@macromedia.com> wrote in message
            news:e9lh3m$sv0$1@forums.macromedia.com...
            > Hi,
            > the
            > since
            > great.
            > TestSlider.mxml
            > <mx:HBox>
            > </mx:HBox>
            > <mx:HBox>
            > </mx:HBox>
            > <mx:HBox>
            > </mx:HBox>
            > </mx:Application>
            > Regards!
            > Santosh
