• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
query based on a test input box
Explorer ,
Jul 20, 2006 Jul 20, 2006
hi
i have this html input box and i want to output a query based on what i put in the input box. what should i do now.
thanks
<form id="form1" name="form1" method="post" action="">
<label>enter id <input type="text" name="textfield" />
</label>
</form>
TOPICS
Advanced techniques
Views
729
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor , Jul 24, 2006 Jul 24, 2006
I posted this as an example of what can be done, and it should work as written. However, the "live dangerously" part is because using this template, as written, would allow anyone to execute ANY query in your database, including DELETE and UPDATE queries, without restriction. This is actualy a simplified form of the one that I actually developed for one of my applications, as that one actually has a login requirement and state management, etc. that I didn't include, in order to keep it simple. ...
Votes
Translate
Translate
LEGEND ,
Read the documentation:
http://livedocs.macromedia.com/coldfusion/7/htmldocs/00001252.htm
page1.html
<form id="form1" name="form1" method="post" action="page2.cfm">
</label>
</form>
page2.cfm
<cfquery name="foo" datasource="bar">
SELECT aField, bField, cField
FROM aTable
WHERE aField = <cfqueryParam value="#form.textfield#"
cfsqltype="cf_sql_varchar">
</cfquery>
<cfoutput query="foo">
#aField# #bField# #cField#
</cfoutput>
> hi
> thanks
> </label>
> </form>
Votes
Translate
Translate
Report
Report
LEGEND ,
Jul 21, 2006 Jul 21, 2006
More simple to write
FROM aTable
WHERE aField = '#form.textfield#'
</cfquery>
No????
JiB�
> </cfoutput>
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 23, 2006 Jul 23, 2006
hi!
do i just inser this '#form.textfield#' just like that or is the form.textfield a different name.
thename of the field in the dataabse is an_number. do i have to declare a variable.
also form in form.textfield, is this exactly the same name?
how is this work
thanks again
Votes
Translate
Translate
Report
Report
Mentor ,
LATEST
I posted this as an example of what can be done, and it should work as written. However, the "live dangerously" part is because using this template, as written, would allow anyone to execute ANY query in your database, including DELETE and UPDATE queries, without restriction. This is actualy a simplified form of the one that I actually developed for one of my applications, as that one actually has a login requirement and state management, etc. that I didn't include, in order to keep it simple. The one I posted is wide open , so use with caution.
Phil
Votes
Translate
Translate
Report
Report
Contributor ,
Be very, very careful when doing this. If you do not validate your input before passing to your SQL statement, someone could put malicious code in the input box and pass it along to your SQL statement.
Votes
Translate
Translate
Report
Report
Explorer ,
thanks
do not validate your input before passing to your SQL statement, ?
how do you validate.
the input will be a string /test just like 123-1234-oop-qa
any examples
also malicous . what do you mean?
and how can i prevent this?
Votes
Translate
Translate
Report
Report
LEGEND ,
Yes it is more simple, but then it is also very simple for me, a
malicious user of the form, to put SQL text into the form field that
will then be run by the database server.
If I put this into the input box: foobar'; DROP TABLE aTable; --
You could be a very unhappy developer.
> FROM aTable
> </cfquery>
> No????
> JiB�
>> </cfoutput>
Votes
Translate
Translate
Report
Report
Mentor ,
Hey, you might as well live real dangerously. This will allow you to enter an entire query in a text box and submit it.
Phil
Votes
Translate
Translate
Report
Report
Explorer ,
live real dangerously. !
i dont get it . is this set of code suppose to be good or bad.
i dont mean to Hesitate on this but you wrote this part :live real dangerously. !
i just wanted to know if this is safe because i dont want to get fired for not being careful
thanks
Votes
Translate
Translate
Report
Report
Resources
Documentation
