5 Replies Latest reply on Jul 20, 2006 6:02 AM by Dvarzoni
    Help Robo help X5
    Dvarzoni
      Im using Robo Help X5.
      When I select menu "Contents & Index", doesn't show notinhg.
      Why?
      Daniela
        • 1. Re: Help Robo help X5
          RoboColum(n) Level 5
          Hi Daniela. I assume you are referring to the CHM file when it is displayed and not the RH tabs themselves. If so, go to the window in the RH Project tab, right click and select Properties. In the Tri-Pane tab and Windows section is a tick box for TOC and Index. Ensure this is ticked and recompile.
          • 2. Re: Help Robo help X5
            CraigCC Level 2
            Hi Daniela,
            Just need a little more information to help.
            Exactly how are accessing the Contents and Index?
            Via the generated help system?
            What format are you generating?
            Exactly what steps are you taking?
            Table of contents and Index items need to be added by the help author before they appear in the generated output.
            Kind Regards
            Craig
            • 3. Re: Help Robo help X5
              Dvarzoni Level 1
              I'm doing the help for the system.
              But I have a doubt and I want to view the help the RoboHelp.
              I click the menu of RoboHelp and select Help/Contents & Index, and doesn't show the Help of RoboHelp.
              This Help is the RoboHelp. Not is the after generated
              Did you understand me?
              And I'm using html Help.
              Sorry, my english is not very well.
              • 4. Re: Help Robo help X5
                Hi Dvarzoni. There is no need to apologise for bad English. It is my first language and mine is awful and as for the Americans on this list.......well! OK. now that I had offended nearly everyone let me try and answer your problem. You seem to be wanting to access the RH Help. Can you check that the "Use Offline Help" option available from the Tools | Options menu item is ticked. This may be your problem. Do come back if it isn't and we'll try again.
                • 5. Re: Help Robo help X5
                  Dvarzoni Level 1
                  Thank you very much.
                  I obtained to consult the Help
                  Daniela
