5 Replies Latest reply on Jul 21, 2006 6:24 AM by 02TransAm
    Help! Remove Movie Clips
    02TransAm
      OK...here's my problem... I am making a portfolio site and I have my thumbnails being created dynamically through XML...very similar to the galleries example in the Sample and Tutorials. Only problem is that I have multiple keyframes with different thumbnails that need to be displyed through a different XML file. I got it to work but the thumbnails from the first frame are still showing on the second frame...How do I remove the dynamically created movie clips?
        • 1. Re: Help! Remove Movie Clips
          blemmo Level 1
          Do a removeMovieClip() for the MCs not needed anymore, or maybe make them invisible by setting the _visible property to false when you want to reuse them later. This should be done when the frame is entered, so you could place this on the frame's script (assumes that the clips are called "thumb0","thumb1" etc. and placed in _root):
          for (var i=0;i<mccount;i++){
          _root["thumb"+i].removeMovieClip();
          //_root["thumb"+i]._visible = false;
          hth,
          blemmo
          • 2. Re: Help! Remove Movie Clips
            02TransAm Level 1
            OK...here's the code...At thebottom of the document, I need to remove the clips created on the next button. This is the same code from the gallery sample file; I just added my own XML file.
            stop();
            import mx.transitions.*;
            _global.thisX = 30;
            _global.thisY = 70;
            _global.stageWidth = 600;
            _global.stageHeight = 400;
            var gallery_xml:XML = new XML();
            gallery_xml.ignoreWhite = true;
            gallery_xml.onLoad = function(success:Boolean) {
            try {
            if (success) {
            var images:Array = this.firstChild.childNodes;
            var gallery_array:Array = new Array();
            for (var i = 0; i<images.length; i++) {
            gallery_array.push({src:images .firstChild.nodeValue});
            displayGallery(gallery_array);
            } else {
            throw new Error("Unable to parse XML");
            } catch (e_err:Error) {
            trace(e_err.message);
            } finally {
            delete this;
            gallery_xml.load("gallery_practices2.xml");
            function displayGallery(gallery_array:Array) {
            var galleryLength:Number = gallery_array.length;
            for (var i = 0; i<galleryLength; i++) {
            var thisMC:MovieClip = this.createEmptyMovieClip("image"+i+"_mc", i);
            mcLoader_mcl.loadClip(gallery_array
            .src, thisMC);
            preloaderMC = this.attachMovie("preloader_mc", "preloader"+i+"_mc", 5000+i);
            preloaderMC.bar_mc._xscale = 0;
            preloaderMC.progress_txt.text = "0%";
            thisMC._x = _global.thisX;
            thisMC._y = _global.thisY;
            preloaderMC._x = _global.thisX;
            preloaderMC._y = _global.thisY+20;
            if ((i+1)%5 == 0) {
            _global.thisX = 20;
            _global.thisY += 80;
            } else {
            _global.thisX += 80+20;
            var mcLoader_mcl:MovieClipLoader = new MovieClipLoader();
            var mclListener:Object = new Object();
            mclListener.onLoadStart = function() {
            mclListener.onLoadProgress = function(target_mc, loadedBytes, totalBytes) {
            var pctLoaded:Number = Math.round(loadedBytes/totalBytes*100);
            var preloaderMC = target_mc._parent["preloader"+target_mc.getDepth()+"_mc"];
            preloaderMC.bar_mc._xscale = pctLoaded;
            preloaderMC.progress_txt.text = pctLoaded+"%";
            mclListener.onLoadInit = function(evt:MovieClip) {
            evt._parent["preloader"+evt.getDepth()+"_mc"].removeMovieClip();
            var thisWidth:Number = evt._width;
            var thisHeight:Number = evt._height;
            var borderWidth:Number = 2;
            var marginWidth:Number = 8;
            evt.scale = 8;
            evt.lineStyle(borderWidth, 0x000000, 100);
            evt.beginFill(0xFFFFFF, 100);
            evt.moveTo(-borderWidth-marginWidth, -borderWidth-marginWidth);
            evt.lineTo(thisWidth+borderWidth+marginWidth, -borderWidth-marginWidth);
            evt.lineTo(thisWidth+borderWidth+marginWidth, thisHeight+borderWidth+marginWidth);
            evt.lineTo(-borderWidth-marginWidth, thisHeight+borderWidth+marginWidth);
            evt.lineTo(-borderWidth-marginWidth, -borderWidth-marginWidth);
            evt.endFill();
            evt._xscale = evt.scale;
            evt._yscale = evt.scale;
            evt._rotation = Math.round(Math.random()*-10)+5;
            evt.onPress = function() {
            this.startDrag();
            this._xscale = 30;
            this._yscale = 30;
            this.origX = this._x;
            this.origY = this._y;
            this.origDepth = this.getDepth();
            this.swapDepths(this._parent.getNextHighestDepth());
            this._x = (_global.stageWidth-evt._width+30)/2;
            this._y = (_global.stageHeight-evt._height+30)/2;
            mx.transitions.TransitionManager.start(this, {type:mx.transitions.Photo, direction:0, duration:1, easing:mx.transitions.easing.Strong.easeOut, param1:empty, param2:empty});
            evt.onRelease = function() {
            this.stopDrag();
            this._xscale = this.scale;
            this._yscale = this.scale;
            this._x = this.origX;
            this._y = this.origY;
            evt.onReleaseOutside = evt.onRelease;
            mcLoader_mcl.addListener(mclListener);
            next_btn.onRelease= function() {
            gotoAndStop(2);
            back_btn.onRelease= function() {
            gotoAndStop(1);
            • 3. Re: Help! Remove Movie Clips
              blemmo Level 1
              You must save the number of items so you can use it in the next button. Add a var to the timeline, or maybe another global:
              _global.mccount = 0;
              In createGallery(), assign the number of thumbnails to this:
              _global.mccount = gallery_array.length;
              Then you can use this number in the next button:
              for (var i=0; i<_global.mccount; i++){
              _root["image"+i+"_mc"].removeMovieClip();
              gotoAndStop(2);
              cheers,
              blemmo
              • 4. Re: Help! Remove Movie Clips
                02TransAm Level 1
                Thanks, I am going to try it!!!!!!!
                • 5. Re: Help! Remove Movie Clips
                  02TransAm Level 1
                  You are awesome!!!! Seriously you are an Action Script Genious!!!!! Thank you sooooo much!!!!!! I worked perfectly!!!! How'd you get so good? Any tips?
