29 Replies Latest reply on Apr 18, 2007 12:39 PM by sanbom
    FlexFactory Example
    Bill White
      I'm wanting to use Spring for my backend for Flex Data Services. I
      found the docs on using a class that implements the FlexFactory
      interface, but the really is not enough detail in the docs to fully
      understand how to fill out the FlexFactory implementation class.
      Has anyone successfully used this class? Do I create a single
      FlexFactory class for all of my destinations that I want to use Spring
      with? Or do I create a FlexFactory impl for each destination?
      Bill
        • 1. Re: FlexFactory Example
          sanclementetech
          I read through that piece of documentation as well ( http://livedocs.macromedia.com/flex/2/docs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=L iveDocs_Parts&file=00001122.html).
          What I did instead is made my Spring classes ApplicationContextAware. I then load my classes at application start-up.
          Ken
          • 2. Re: FlexFactory Example
            Bill White Level 1
            Thanks for the reply Ken. So are you just making your Flex Assembler classes for each domain object ApplicationContextAware? Or are you using Spring in some deeper level behind the Assemblers? And have you managed to integrate Acegi security as well doing this?
            Thanks for your help.
            Bill
            • 3. Re: FlexFactory Example
              sanclementetech Level 1
              I have a base class that I use for my DAO classes that is ApplicationContextAware. I figure you could do the same with your assembler classes, but I am not currently making them ApplicationContextAware.
              My DAO classes extends HibernateDaoSupport implements Serializable , ApplicationContextAware. This way I have very little code in my DAO classes.
              As far as the assembler goes, pretty much the same. My base class is a workhorse for 80% of what I have to do. I extend my base class functionality for each assembler I need. but generally only need to let it know what bean to load.
              public class DAOAssembler implements flex.data.assemblers.Assembler
              private ApplicationContext ac;
              private GCHibernateSupport bean;
              private SessionFactory sessionFactory;
              private String DAO_CLASS = "";
              private String ID_COLUMN = "";
              private static String CONTEXT_LOCATION = "/spring-config.xml";
              private Logger logger;
              public DAOAssembler()
              this.startLogger();
              public DAOAssembler(String dao, String idColumn) throws Exception
              try
              this.startLogger();
              logger.debug("DAO: " + dao);
              logger.debug("ID: " + idColumn);
              this.DAO_CLASS = dao;
              this.ID_COLUMN = idColumn;
              this.ac = new ClassPathXmlApplicationContext(CONTEXT_LOCATION);
              bean = (GCHibernateSupport) this.ac.getBean(this.DAO_CLASS);
              sessionFactory = bean.getSessionFactory();
              catch(Exception e)
              logger.error(e.toString(), e);
              throw(e);
              I extend this to something like
              package com.sanclementetech.dao.flex;
              import com.sanclementetech.dao.DAOAssembler;
              * @author Ken
              public class ContactAddressTypeAssembler extends DAOAssembler {
              private static String DAO = "ContactAddressTypeDAO";
              private static String ID = "contactAddressTypeId";
              public ContactAddressTypeAssembler() throws Exception
              super(DAO, ID);
              I am not a Spring expert but this works. Then I can use FDS to access the assembler, which communicates with the my DAO's which are already loaded because they are ApplicationContextAware.
              So I guess the real idea is to use the Assemblers as POJO's and then have your other Spring "stuff" ApplicationContextAware so that it can be resolved.
              Hope this helps.
              Ken
              • 4. Re: FlexFactory Example
                Bill White Level 1
                This is good stuff. Thanks for the post! I'll give this a try as an alternative to the FlexFactory since it doesn't appear to be a well documented function yet.
                Thanks!
                • 5. Re: FlexFactory Example
                  Bill White Level 1
                  Update: I've been unable to find any detailed documentation on how to use the FlexFactory and no one seems to be discussing it much in the forums here or elsewhere. Therefore, I began playing around with it in order to see if I could make it work. As best I can tell, here is the basic premise:
                  When working with FDS and Java, you need an Assembler class to create, update, delete, etc the Java objects on the backend that will be displayed on the flash frontend. You can create your assemblers manually and list them in the data-management-service.xml file to access them from the flash client. However, if you want to create these assemblers using Spring as a way to create/inject them with dependencies, you need to use the FlexFactory. At first I tried just creating the Assemblers with hardcoded Spring applicationContexts, but I realized I should be able to use these without Spring specific references. So what I needed to do was create them using Spring and inject properties into them. If you try to do this using the ContextLoaderListener to initialize your Assemblers, you quickly find that it backfires. Even if you use the ContextLoaderListener to initialize the assemblers with Spring, the FDS will create them again using its own factories, essientially creating two different assemblers: one with spring-injected settings and one (created by Flex) which was not injected by Spring upon creation and therefore this instance will throw NullPointerExceptions when Flex tries to use it.
                  The answer is the FlexFactory. (the docs only say this is the way to integrate Spring into Flex; it gives no real detail as to why, when, or how to make use of this class; nor does it explain what the FactoryInstance class is or does; shame shame!)
                  The FlexFactory is used to override the basic factory that Flex uses to create your Assemblers. By overriding the default Factory with your own class that implements FlexFactory, you basically prevent FDS from generating Assemblers listed in the data-management-config.xml file on its own. What you have to do is create this class, list it in the services-config.xml file in a 'factories' tag, and then use it to create and return your Assemblers in the lookup method. I create an applicationContext in the constructor of the factory and then to applicationContext.getBean() calls for each of my assemblers. Then in the lookup method I check the 'source' attribute being passed into the method and return the corresponding Assembler. As for the createFactoryInstance(String, ConfigMap) method where you have to return a FactoryInstance object, I just create a FactoryInstance using the passed parameters and return it. This is apparently how Flex tracks the runtime instance of the Factory that is created upon initialization. (at least that is what I'm guessing is the case).
                  Hope this helps clear the issue of what the FlexFactory does for those of you just getting started. If anyone else has any clarification on this, or knows that I'm 'doing it wrong', please chime in.
                  Bill
                  • 6. FlexFactory Example
                    mpeterson
                    Hi Bill. If you haven't already found it, there is some additional documentation on FlexFactory usage here:
                    Let me know if this is useful to you.
                    - Mike Peterson
                    Adobe Flex documentation team
                    • 7. Re: FlexFactory Example
                      Mike,
                      I don't think that is the right link. IT gets me "Calling services in ActionScript".
                      The documentation that I have found is here - http://livedocs.macromedia.com/flex/2/docs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=L iveDocs_Parts&file=00001122.html
                      but it does not have any additional information. What would be helpful is an example showing the use of the FlexFactory with Java.
                      • 8. Re: FlexFactory Example
                        Bill White Level 1
                        Thanks for the reply Mike. Yes, this is same documentation that I (and Ken) have both reviewed. Unfortunately it is quite lacking in depth. It does not describe the FactoryInstance object in any real detail. It also fails to provide any useful examples. It would be better if we had a link at the bottom titled "Looking at a FlexFactory Example" that led to a page will a more complete, real-world example similar to the "Looking at a managed association example" found here.
                        • 9. Re: FlexFactory Example
                          jvroom
                          My apologies for the delay in my response and for the lack of detailed docs. We'll work on improving the documentation, but in the meantime the basic idea is that you have a single FlexFactory instance which gets created for each flex-enabled web application. This instance can have its own configuration properties though in this case, we do not have any required properties to configure the factory. In your services-config.xml file, you'd add something like the following:
                          <factories>
                          <factory id="spring" class="flex.samples.factories.SpringFactory" />
                          </factories>
                          Flex will create one FlexFactory instance for each tag you specify. Flex will use this one global FlexFactory implementation for each destination which specifies that factory by its id using the factory tag. For example, you might have this in your remoting-config.xml file:
                          <destination id="WeatherService">
                          <properties>
                          <factory>spring</factory>
                          <source>weatherBean</source>
                          </properties>
                          </destination>
                          when this tag is encountered at startup, FDS calls the FlexFactory.createFactoryInstance method. That method gets the <source> and any other attributes it expects in the configuration. Any attributes you access from the ConfigMap parameter are marked as "expected" and will not cause a configuration error so you can extend Flex's default configuration in this manner. When flex wants to actually needs an instance of the component for this destination, it calls the FactoryInstance.lookup method to retrieve the individual instance for that destination.
                          Here's a working implementation of the SpringFactory class:
                          package flex.samples.factories;
                          import org.springframework.context.ApplicationContext;
                          import org.springframework.web.context.support.WebApplicationContextUtils;
                          import org.springframework.beans.BeansException;
                          import org.springframework.beans.factory.NoSuchBeanDefinitionException;
                          import flex.messaging.FactoryInstance;
                          import flex.messaging.FlexFactory;
                          import flex.messaging.config.ConfigMap;
                          import flex.messaging.services.ServiceException;
                          * This interface is implemented by factory components which provide
                          * instances to the flex messaging framework. To configure flex data services
                          * to use this factory, add the following lines to your services-config.xml
                          * file (located in the WEB-INF/flex directory of your web application).
                          * &lt;factories&gt;
                          * &lt;factory id="spring" class="flex.samples.factories.SpringFactory" /&gt;
                          * &lt;/factories&gt;
                          * You also must configure the web application to use spring and must copy the spring.jar
                          * file into your WEB-INF/lib directory. To configure your app server to use spring,
                          * you add the following lines to your WEB-INF/web.xml file:
                          * &lt;context-param&gt;
                          * &lt;param-name&gt;contextConfigLocation&lt;/param-name&gt;
                          * &lt;param-value&gt;/WEB-INF/applicationContext.xml&lt;/param-value&gt;
                          * &lt;/context-param&gt;
                          * &lt;listener&gt;
                          * &lt;listener-class&gt;org.springframework.web.context.ContextLoaderListener&lt;/listener- class&gt;
                          * &lt;/listener&gt;
                          * Then you put your spring bean configuration in WEB-INF/applicationContext.xml (as per the
                          * line above). For example:
                          * &lt;?xml version="1.0" encoding="UTF-8"?&gt;
                          * &lt;!DOCTYPE beans PUBLIC "-//SPRING//DTD BEAN//EN" " http://www.springframework.org/dtd/spring-beans.dtd"&gt;
                          * &lt;beans&gt;
                          * &lt;bean name="weatherBean" class="dev.weather.WeatherService" singleton="true"/&gt;
                          * &lt;/beans&gt;
                          * Now you are ready to define a destination in flex that maps to this existing service.
                          * To do this you'd add this to your WEB-INF/flex/remoting-config.xml:
                          * &lt;destination id="WeatherService"&gt;
                          * &lt;properties&gt;
                          * &lt;factory&gt;spring&lt;/factory&gt;
                          * &lt;source&gt;weatherBean&lt;/source&gt;
                          * &lt;/properties&gt;
                          * &lt;/destination&gt;
                          * @author Jeff Vroom
                          public class SpringFactory implements FlexFactory
                          private static final String SOURCE = "source";
                          * This method can be used to initialize the factory itself. It is called with configuration
                          * parameters from the factory tag which defines the id of the factory.
                          public void initialize(String id, ConfigMap configMap) {}
                          * This method is called when we initialize the definition of an instance
                          * which will be looked up by this factory. It should validate that
                          * the properties supplied are valid to define an instance.
                          * Any valid properties used for this configuration must be accessed to
                          * avoid warnings about unused configuration elements. If your factory
                          * is only used for application scoped components, this method can simply
                          * return a factory instance which delegates the creation of the component
                          * to the FactoryInstance's lookup method.
                          public FactoryInstance createFactoryInstance(String id, ConfigMap properties)
                          SpringFactoryInstance instance = new SpringFactoryInstance(this, id, properties);
                          instance.setSource(properties.getPropertyAsString(SOURCE, instance.getId()));
                          return instance;
                          * Returns the instance specified by the source
                          * and properties arguments. For the factory, this may mean
                          * constructing a new instance, optionally registering it in some other
                          * name space such as the session or JNDI, and then returning it
                          * or it may mean creating a new instance and returning it.
                          * This method is called for each request to operate on the
                          * given item by the system so it should be relatively efficient.
                          * <p>
                          * If your factory does not support the scope property, it
                          * report an error if scope is supplied in the properties
                          * for this instance.
                          public Object lookup(FactoryInstance inst)
                          SpringFactoryInstance factoryInstance = (SpringFactoryInstance) inst;
                          return factoryInstance.lookup();
                          static class SpringFactoryInstance extends FactoryInstance
                          SpringFactoryInstance(SpringFactory factory, String id, ConfigMap properties)
                          super(factory, id, properties);
                          public String toString()
                          return "SpringFactory instance for id=" + getId() + " source=" + getSource() + " scope=" + getScope();
                          public Object lookup()
                          ApplicationContext appContext = WebApplicationContextUtils.getWebApplicationContext(flex.messaging.FlexContext.getServlet Config().getServletContext());
                          String beanName = getSource();
                          try
                          return appContext.getBean(beanName);
                          catch (NoSuchBeanDefinitionException nexc)
                          ServiceException e = new ServiceException();
                          String msg = "Spring service named '" + beanName + "' does not exist.";
                          e.setMessage(msg);
                          e.setRootCause(nexc);
                          e.setDetails(msg);
                          e.setCode("Server.Processing");
                          throw e;
                          catch (BeansException bexc)
                          String msg = "Unable to create Spring service named '" + beanName + "' ";
                          e.setMessage(msg);
                          e.setRootCause(bexc);
                          e.setDetails(msg);
                          throw e;
                          Let me know if you have any questions or run into any problems. Regards,
                          Jeff Vroom
                          Flex Data Services Team
                          • 10. Re: FlexFactory Example
                            Bill White Level 1
                            Excellent! Thanks so much Jeff. This is what I was looking for all along. This kind of example is exactly what should find its way into the documentation. I modified your example to work with the data management service, replacing your service class with my assembler. I also had to put my destination tags into the data-management-config.xml file rather than the remote-config.xml and I had to use the flex.data.adapters.JavaAdapter rather than the flex.messaging.services.remoting.adapters.JavaAdapter. Now it seems to be working and I just need to figure out how to integrate Acegi authentication into this. (I'll make that a new post)
                            Thanks!
                            • 11. Re: FlexFactory Example
                              OK. You gusy lost me. So does this mean that my BaseAssembler needs to not only extend flex.data.assemblers.Assembler but also flex.messaging.FlexFactory?
                              NOT
                              public class BaseAssembler implements flex.data.assemblers.Assembler
                              BUT THIS
                              public class BaseAssembler implements flex.data.assemblers.Assembler, flex.messaging.FlexFactory
                              • 12. Re: FlexFactory Example
                                jvroom Level 1
                                Hi Ken,
                                Your assembler class does not implement FlexFactory. You only need one FlexFactory implementation for each source of Java objects that you want to use with FDS either as remote object destinations or data management services assembler classes.
                                Here's a copy of some more complete instructions I wrote on integrating FDS with Spring. Hopefully this will help. Best,
                                Jeff
                                --- Integrating FDS with Spring
                                1. Step for configuring Spring and FDS. This step only applies if you have
                                  not already installed spring in your web application.
                                  • Copy the spring.jar file into your WEB-INF/lib of your web application.
                                  • Add the spring context param and listener to your web.xml file:
                                  <context-param>
                                  <param-name>contextConfigLocation</param-name>
                                  <param-value>/WEB-INF/applicationContext.xml</param-value>
                                  </context-param>
                                  <listener>
                                  <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
                                  </listener>
                                2. Register the spring factory with FDS:
                                  a) Get a copy of flex.samples.factories.SpringFactory.java. Compile
                                  it and put it in your classpath someplace convenient. For the purposes of this sample,
                                  we'll assume it lives at flex.samples.factories.SpringFactory.
                                  b) Add the following configuration to your WEB-INF/flex/services-config.xml file:
                                  <factories>
                                  </factories>
                                3. Define your components in spring's XML file. Given the above spring
                                  configuration, they would be placed in WEB-INF/applicationContext.xml. This file can
                                  contain components which are intended to be exposed to flex clients as
                                  remote objects as well as classes to be used as Flex Data Management Services (FDMS)
                                  assembler implementations using the Java adapter.
                                  Just as with all FDMS destinations that use the Java adapter, if your class is intended to be
                                  used with FDMS, it either should implement the the flex.data.assembler.Assembler interface
                                  or it should have fill, get, and sync methods which are suitable to be configured via the
                                  fill-method, get-method, and sync-method tags in the FDMS configuration.
                                  To be constructed by Spring, your component should have a zero argument constructor so
                                  Spring can construct an instance. Your applicationContext.xml file might look like:
                                  <?xml version="1.0" encoding="UTF-8"?>
                                  <!DOCTYPE beans PUBLIC "-//SPRING//DTD BEAN//EN" " http://www.springframework.org/dtd/spring-beans.dtd">
                                  <beans>
                                  <bean name="weatherBean" class="dev.weather.WeatherService" singleton="true"/>
                                  <bean name="myAssembler" class="dev.assemblers.MyAssembler" singleton="true"/>
                                  </beans>
                                4. Add your flex destination configuration for the components you want to expose to
                                  flex clients. Since these components use the spring factory we define, we add the
                                  additional tag <factory>spring</factory> and the <source> attribute is used to refer
                                  to the spring component's bean name, not the class name as with the default factory.
                                  a) For Remote object destinations you place your destinations inside of the <service> tag
                                  which refers to the flex.messaging.services.RemotingService,
                                  (by convention this may be in WEB-INF/flex/remoting-config.xml). For example, your
                                  remote destination configuration might look like:
                                  <properties>
                                  </properties>
                                  </destination>
                                  b) For FDMS destinations that use the Java adapter, you add your destinations to the
                                  service tag which refers to flex.data.DataService
                                  (which by convention may be in WEB-INF/flex/data-management-config.xml). Make sure you
                                  use the Java adapter for your destination. An example FDMS destination might look like:
                                  <destination id="MyFDMSDestination">
                                  <properties>
                                  <source>myAssembler</source>
                                  </properties>
                                  </destination>
                                See the FDMS documentation for more details on configuring FDMS destinations which use the
                                Java adapter.
                                • 13. Re: FlexFactory Example
                                  So if I have more than one object i would
                                  <factories>
                                  <factory id="Object1SpringFactory" class="flex.samples.factories.SpringFactory" />
                                  <factory id="Object2SpringFactory" class="flex.samples.factories.SpringFactory" />
                                  <factory id="Object3SpringFactory" class="flex.samples.factories.SpringFactory" />
                                  </factories>
                                  <beans>
                                  <bean name="bean1" class="dev.assemblers.MyAssembler1" singleton="true"/>
                                  <bean name="bean2" class="dev.assemblers.MyAssembler2" singleton="true"/>
                                  <bean name="bean3" class="dev.assemblers.MyAssembler3" singleton="true"/>
                                  </beans>
                                  <destination id="MyFDMSDestination2">
                                  <properties>
                                  <source>bean2</source>
                                  <factory>Object2SpringFactory</factory>
                                  </properties>
                                  </destination>
                                  etc.
                                  • 14. Re: FlexFactory Example
                                    bela2000
                                    Hi, Can you tell me pls where to find the jar containing flex.messaging.FactoryInstance ?
                                    I ve put flex-messaging-common.jar already on the classpath, but there is no sign of this inside.
                                    • 15. Re: FlexFactory Example
                                      bela2000 Level 1
                                      Hi, can you tell me pls where to find the jar containing flex.messaging.FactoryInstance ? thanks
                                      • 16. Re: FlexFactory Example
                                        T._Ruggles
                                        It's in WEB-INF/lib/flex-messaging.jar.
                                        • 17. Re: FlexFactory Example
                                          bela2000 Level 1
                                          Thank you Tom.
                                          Is there any licensing issue with this jar ( flex-messaging.jar ) being extracted from fds2 which is itself licensed ?
                                          • 18. Re: FlexFactory Example
                                            cardinalsolutions
                                            Jeff,
                                            Thanks for posting sample code for FDS-Spring integration. I'm trying to compile your SpringFactory class, and I'm having issues resolving SpringFactoryInstance. It's not inside the main spring.jar file. If you know which Spring jar the SpringFactoryInstance class is located, pls post the reply. Thanks,
                                            /Roman
                                            • 19. Re: FlexFactory Example
                                              seth_hodgson
                                              Hi Roman,
                                              SpringFactoryInstance is a nested class within SpringFactory.java which is available as a download from the Flex Exchange on Adobe.com ( http://www.adobe.com/cfusion/exchange/#loc=en_us&view=sn611&viewName=Flex%20Extension&auth orid=70170511&page=0&scrollPos=0&subcatid=0&snid=sn611&itemnumber=0&extid=1035406&catid=0)
                                              Bela, I'm not in legal so I can't comment directly on the licensing issues with extracting flex-messaging.jar from FDS2. Can you provide some more details on what you're trying to accomplish?
                                              Seth
                                              • 20. Re: FlexFactory Example
                                                cardinalsolutions Level 1
                                                Seth,
                                                Thanks for your post. I've figured it out, but have another question for you:
                                                I got the SpringFactory class and all the configuration for both Flex and Spring defined so that they can talk to each other (I have them both as separate projects in Eclipse). Originally, I had a new destination inside remoting-config.xml that mapped my POJO object. Then, in my .mxml file I simply declared remoteObject referencing POJO by the destination id, and called its methods.
                                                Now, having this SpringFactory class, how am I going to access my Spring bean which is also mapped to some destination id inside remoting-config.xml? If it's the matter of simply calling the Spring bean by its destination, then how the SpringFactory fits in this picture.
                                                I appreciate your reply. Thanks,
                                                /Roman
                                                • 21. FlexFactory Example
                                                  seth_hodgson Level 1
                                                  If you reference your POJO in a remoting service destination directly, FDS will create the bean instance and Spring isn't involved. By using the SpringFactory, you're allowing FDS to get the bean instance from the Spring framework which will perform any necessary dependecy injection, etc.
                                                  Hope that helps,
                                                  Seth
                                                  • 22. Re: FlexFactory Example
                                                    Seth,
                                                    Thanks, that makes sense. I want to pass data from my Spring bean (which I registered inside remoting file as a source) to the Flex app to eventually display it on my flash file (whatever gets created after compiling .mxml file). Do I invoke SpringFactory directly from .mxml file passing the Spring bean name and properties (i.e. createFactoryInstance(beanName, properties)), or there's a third piece to it?
                                                    /Roman
                                                    • 23. Re: FlexFactory Example
                                                      Hi Roman,
                                                      You don't need to invoke SpringFactory directly. Take a look at Jeff's comment earlier in this thread. He uses the following example:
                                                      <factories>
                                                      </factories>
                                                      <properties>
                                                      </properties>
                                                      </destination>
                                                      In your MXML app, you'd create a RemoteObject with its destination set to "WeatherService" and then invoke the methods defined by the 'weatherBean' class.
                                                      This all works exactly the same as a regular remote object as far as you're concerned. The only difference is that the destination gets its internal weatherBean instance from Spring rather than creating a bean instance directly using reflection.
                                                      Best,
                                                      Seth
                                                      • 24. Re: FlexFactory Example
                                                        Seth,
                                                        Thanks again for your post. I think I got the idea of how it all works. I've finally managed to put all the pieces together. I set the FDS Logger level to debug, so that I can see the output. I now get pretty nasty FDS error message when trying to access my SpringBean from mx:RemoteObject tag. It looks like it cannot resolve my SpringBean destination resulting in a NullPointerException. I'll go back to check all the config files. Maybe, my SpringFactory didn't initialize bean properly.
                                                        /Roman
                                                        • 25. Re: FlexFactory Example
                                                          Seth,
                                                          Thanks for your previous post. I think I now got all the pieces together. I know my SpringFactory works because I after I've defined it inside services-config, I see my debug statements inside SpringFactory.createFactoryInstance() when app server starts up kicking the FDS service. However, when I invoke my SpringBean from inside the flex app, I get an error saying that it cannot find my Spring service declared inside remoting-config. Inside the app server console it says:
                                                          "Spring service named 'bus.ProductManager' does not exist" with the root cause "rootCause = org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'bus.ProductManager' is defined".
                                                          The ProductManager class is in fact my Spring bean declared as a source inside remoting-config.
                                                          I've kept all my configuration very similar to the one in the article about SpringFactory. I guess I'll go thru it one more time. In a meantime, if you have any suggestions as of why FDS cannot locate my spring bean, please let me know. Thanks,
                                                          /Roman
                                                          • 26. Re: FlexFactory Example
                                                            Seth,
                                                            Thanks for all your help. I finally got it working. My problem was that inside remoting-config file I was using class name for "source" instead of the bean name declared inside applicationContext.xml.
                                                            One thing though: the whole FDS to Spring enchilada only works if I declare my SpringBean inside applicationContext.xml with id attribute (<beans><bean id="SpringBean" class="pachage.class" etc). If I change the id attribute of my bean into "name" like it says in the article (<bean name="SpringBean" etc), the whole app doesn't even get loaded.
                                                            Thanks again,
                                                            /Roman
                                                            • 27. Re: FlexFactory Example
                                                              That's great news Roman :)
                                                              And you're correct. The readme file's applicationContext.xml section has:
                                                              <bean name="..." ... />
                                                              rather than
                                                              <bean id="..." .../>
                                                              We'll correct this and update the extension.
                                                              Best,
                                                              Seth
                                                              • 28. Re: FlexFactory Example
        marcel.panse Level 1
        Hey,
        First of all good job on the FlexFactory!. I have all working fine.. Loading the flex servlets with spring's ServletWrappingController gives me an advantage to bind interceptors (like a loginInterceptor) with the flex servlets.
        Now i have the following question: Springs 2.0 Session scope proxy beans.
        I have a session scoped proxy bean representing a login object for every (http) session on the website. This is injected in several managers, and thus the managers can check wether the user is logged in and if he has enough rights to call the method etc.
        This still works fine when using Flex RPC calls to my Spring managers with the Spring Factory.
        But it aint working with Flex FDMS. Probebly because the FDMS keeps state (and session) internal to flex. And new call go straight to the server instead of going through some HTTP call which gets catched by the Spring context.
        So how is this Flex FDMS working internally? I thought it should go through the messagebroker or something (which is a flex servlet, so should have a http session?).
        • 29. Re: FlexFactory Example
        sanbom
        Hi All
        This Flex factory works fine If I use default fill and sync methods .
        The moment i try to use mu custom fill and sync methods by using the foll tags in data-management-config.xml
        <properties>
        <use-transactions>false</use-transactions>
        <source>transAssembler</source>
        <scope>request</scope>
        <metadata>
        <identity property="transKey"/>
        </metadata>
        <network>
        <session-timeout>20</session-timeout>
        <paging enabled="false" pageSize="10" />
        <throttle-inbound policy="ERROR" max-frequency="500"/>
        <throttle-outbound policy="REPLACE" max-frequency="500"/>
        </network>
        <server>
        <fill-method>
        <name>searchTransactions</name>
        <params>com.citi.vo.TransMaintenanceVO</params>
        </fill-method>
        <sync-method>
        <name>syncTransactions</name>
        </sync-method>
        </server>
        </properties>
        I get the foll error
        flex.messaging.config.ConfigurationException: Unused tags in <properties> found. Please fix them before continuing:
        '/scope' in destination with id: 'transService' from file: data-management-config.xml
        '/server/sync-method' in destination with id: 'transService' from file: data-management-config.xml
        '/server/fill-method' in destination with id: 'transService' from file: data-management-config.xml
        at flex.messaging.config.MessagingConfiguration.reportUnusedProperties(MessagingConfiguratio n.java:432)
        at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:110)
        at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1139)
        at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:791)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:127)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
        at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Htt p11BaseProtocol.java:665)
        at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
        at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.ja va:81)
        at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
        at java.lang.Thread.run(Thread.java:595)
        Apr 18, 2007 3:04:59 PM org.apache.catalina.core.StandardWrapperValve invoke
        But if I do not use spring factory and use the fully qualified name of the assembler in the source tag everything works fine.
        Please suggest how to use spring factory with this configuration
