1 Reply Latest reply on Aug 28, 2008 7:05 PM by Lukewig
    loads of sprites and big images?
    OleKristianHH
      Hallo, I have a few questions if someone has time.
      By default there are 150 sprite channels in director, is there a reason for that or can I safely increase it? I am planning to make a small application that will need a lot of sprites (2d particle systems among other things). Could I increase it to say 1000?
      What is the best way to work with big pictures that are moving? I am planning to have a big moving sprite as my background (like a side scroll game). But last time I tried that I got a lot of "tearing". Is there anyway to remove or minimize it?
        • 1. Re: loads of sprites and big images?
          Lukewig Level 1
          HI,
          You can change the number of sprite channels in the movie property dialog (command-shift-d). I think there is a limit (maybe 1000?) - I'm not sure because anytime I've need a lot of 'sprites' (such as in a particle system) its been more efficient for me to use imaging lingo and paint many particles into a single sprite (or the stage)
          I believe there is some limit with 'big images' - but again I've usually used imaging lingo to animate smaller slices of the image. I did some experiments a while ago - and to scroll around a 10,000 x 10,000 'image', I ended up using 256x256 pixel tiles (I think - my memory is a bit vague) I was comparing the speed scrolling 60 small tiles vs. 12 medium vs 4 large tiles) You might want to do some similar tests.
          Cheers
          Luke
