2 Replies Latest reply on Sep 21, 2006 2:44 AM by Andra Veraart
    ExternalInterface.available returns false on a Mac
    Andra Veraart
      Hi there!
      I'm triyng to get the browsers back-button to work with my flash site. The general principle is this:
      There is an index.html page containing an (not yet) hidden Iframe and the flash movie.
      The Iframe contains page A, which starts with JavaScript calling a BACK-function on the index-page.
      The BACK-function triggers an AS-function in the flash-movie that activates its own back-button, and then changes the URL of the Iframe to Page B. This causes a new History to be added to the browser.
      The flash movie now contains 5 frames (labeled in the middle of the stage) and two navigation buttons: back (Terug) and forward (Verder). Those buttons do exactly what you'd expect them to do (prevFrame and nextFrame).
      On a PC (IE) this seems to work pretty well. But on a mac nothing seems to work propperly.
      I've got a testpage at: http://www.multimediamatters.nl/test
      Here's the code I have on the first frame.
      _root.terug.onRelease = function(){
      terugF = function(){
      if (_root._currentframe > 1){
      else {
      import flash.external.*;
      var isAvailable:Boolean = ExternalInterface.available;
      var txtField2:TextField = this.createTextField("txtField", this.getNextHighestDepth(), 300, 0, 200, 50);
      txtField2.border = true;
      txtField2.text = "ExternalInterface.available = "+isAvailable.toString();
      var methodName:String = "goHome";
      var instance:Object = null;
      var method:Function = terugF;
      var wasSuccessful:Boolean = ExternalInterface.addCallback(methodName, instance, method);
      var txtField:TextField = this.createTextField("txtField", this.getNextHighestDepth(), 0, 0, 200, 50);
      txtField.border = true;
      txtField.text = "ExternalInterface.addCallback = "+wasSuccessful.toString();
      Somehow the ExternalInterface doesn't seem to get loaded. Any suggestions to solve this?
      Thanks in advance.
      The condition if (_root._currentframe > 1){ doesn't work on a PC either. It always calls _root.terug.onRelease(). I can't figure out why...
