1 Reply Latest reply on Sep 7, 2006 9:20 AM by yaroze
    Webservice and Array parm
    skm2MX Level 1
      Have a web service that requires an array of objects (records with multiple fields).
      Hard coding an array in the
      <request>
      <array>["AB", "CD"]</array>
      </request>
      works just fine because the parameter/arguement is recognized as an array type.
      But if you load an array and try the following
      <request>
      <array>myArray</array>
      </request>
      it doesn't work properly due to the parameter/arguement being recognized as a string.
      It is a syntax issue, just don't recall the proper syntax.
      Anyone know how the syntax should be written so that an array can be passed correctly???
      Thanks in advance!
