I am a newby to the Flex development and have a question on
JRun integration environment. Came across the Contact sample (
http://livedocs.macromedia.com/flex/2/docs/wwhelp/wwhimpl/js/html/wwhelp.htm?href=00000138.html)and was able to make the Contact sample application working.
However, I modified the ContactDAO class to get the Contacts static
data instead from the database. I have compiled the Java code with
the JAVA SDK I have installed from Sun and copied the class file to
the JRun classes directory. Now the application is not retrieving
any data. Even if I compile the original ContactDAO.java (without
modifying the code), the grid control is not returning any data.
So, my question is what java compiler was used to compile the
sample classes that were provided with the tools. Please help.
