1 Reply Latest reply on Sep 12, 2006 6:51 AM by tdriley
    Memory limit?
    Aladin102
      Director has a certain amount of memory allocated to the program. It can be viewed with the memorySize property. Is there any way to increase the amount of memory that Director can use? Right now, the memorySize is set to the amount of physical RAM on the PC (1 GB). Is it possible to get Director to use the HD virtual RAM (page file) as part of the memory allocated to the program? Or do I have to buy more physical RAM in order to increase the available RAM for Director?
      Thanks!
        • 1. Re: Memory limit?
          tdriley Level 1
          There are some memory options in the publish settings, maybe you can specify you want to use more, and it will use the pagefile if you specify more than the amount of physical available? buddyAPI has some usefull functions for returning info about available physical and virtual memory.. Can't remember if it has any controls for specifying how much to allocate.
          T
