2 Replies Latest reply on Sep 4, 2006 3:43 PM by icecappacino
    PopUpManager.createPopUp()
    icecappacino Level 1
      Hey,
      I have a movieclip hereforth known as "a" has a class attached to it that creates a PopUp. When running this movie the PopUp works fine. However when loading "a" into a movieclip hereforth known as "b"...it doesnt work.
      Running a trace on a reference to the PopUp returns as nul when running movie "b" while a will return a reference.
      What would cause the popup to work when running "a" initial yet result in "null" when loaded into "b"?
      Kendall
        • 1. Re: PopUpManager.createPopUp()
          injpix Level 3
          It sounds like a scope issue. Are you using “_root” anywhere in that class file? If so that would be an issue that can be fixed by replacing it by “this” or “_parent”. Also how are you creating an instance of this class? Are you doing it via the symbol or timeline? That would also be a possible problem. If you post the code it will reveal the problem.
          • 2. Re: PopUpManager.createPopUp()
            myIP,
            I was using "this" then i started using "_root"
            I'm creating an instance of it from at runtime .It is executed from within a class's function that is attached to a movieclip. alertWindow results in null
