2 Replies Latest reply on Sep 1, 2006 1:37 PM by pbs911
    shortcut problem
    pbs911
      I am having a problem linking to an external .chm in my software application help. I've read the posts about shortcut problems and am trying to use Pete Lee's javascript. I saved this javascript in a file names 'getChmDir.js' which I added to my RoboHelp project and then added as a baggage file. I included the following in the HEAD of my truecode:
      <script type="text/javascript"
      language=JavaScript
      src="../getChmDir.js"></script>
      What I'm trying to do is use an image with a hyperlink to a specific file in an external .chm. My current hyperlink is:
      JavaScript:Shortcut('HH.exe','MaestroFlowcharts.chm::\Task_Flow\cc_start_care.htm')
      This hyperlink will not work. I'm getting a message 'A Runtime Error has occurred. ...Error:Object expected.' 'is as follows.
      My thinking was that I need to supply the application, followed by the .chm file name and file within the chm. I don't know much about javascript, but I've been successful in applying Pete's javascript for mynotes and Peter Grainge's javascript for show all/hide all.
      I would sincerely appreciate any assistance. Thank You!
      Pam
        • 1. Re: shortcut problem
          Level 2
          Pam,
          While there are problems with shortcut controls, opening an external .chm should still work with a direct call <A HREF= "MaestroFlowcharts.chm::\Task_Flow\cc_start_care.htm">. This provided the external and calling .chm are in the same folder. I'm also assuming you are calling from a .chm as opposed to calling a .chm from WebHelp.
          John
          • 2. Re: shortcut problem
            pbs911 Level 1
            Thanks for your reply, John. Actually the direct call <A HREF= "MaestroFlowcharts.chm::\Task_Flow\cc_start_care.htm"> would not work inside my application where the Help is called. However, I did receive help with this problem and solved it by changing the javascript and the Script Source that I was using.
            Again, thank you for replying.
