2 Replies Latest reply on Sep 2, 2006 1:16 AM by jagguy99
    scroll and button
    jagguy99
      q)Is there any function in flash to make the screen scroll with a large background covering 2 screen sizes?
      q) when loading movie clips on screen I am using _visible property set to false when making them dissappear, is this the standard way or do you need to unload the bitmap image in the movieclip?
        • 1. Re: scroll and button
          Level 7
          You simulate it by changing the _x property of the background image.
          Put the background image into a movieclip and give the instance a name
          like bg_mc. Using an onenterframe of the bg_mc clip or some other
          animation timer move the bg_mc in the direction you want to scroll like
          bg_mc._x -= 10 if you wanted to move the clip 10 pixels at a time for
          example. When the background gets halfway move the bg_mc._x = 0 and
          start again to continue the loop.
          Depends on why you are hiding it. If you no longer need the bitmap use
          unloadMovie to free memory. If you plan on toggling the clip on and off
          use _visible to keep the image in memory. If you are done with the clip
          altogether use removeMovieClip instead to release all properties and
          clip handlers.
          James O'Reilly - JOR
          www.jamesor.com
          • 2. Re: scroll and button
            jagguy99 Level 1
            If the background is large can I clip the thing somehow?
            I was talking about having a tiled background to make display and operations on the background easier (for the case of a game etc).
            Sounds like flash doesn't provide anything for this so I will have to create like like in directx/c++ manually.
