3 Replies Latest reply on Sep 6, 2006 3:07 AM by Newsgroup_User
    Convert circle (ellipse) to letter "C"
    Level 7
      There are no fonts with the letter "C" in the same shape I want. How can I
      convert a circle, ellipse, to the shape of "C"? Yes, I am new to FW, but
      it's really, really easy in Corel Draw :(
      Hugh
        • 1. Re: Convert circle (ellipse) to letter "C"
          Level 7
          It's really easy in Fireworks as well.
          Drag out two vector Ellipse's, one small than the other in the shape and
          size you want for your 'C'
          With the smaller 'C' on top of the larger one, select them both (hold down
          the shift key)
          Go to Modify from the top menu, and select Combine Paths and then Punch.
          Then drag out a rectangle or whatever shape you require and place it were
          you want the gap in the 'C'
          Select the circle and the rectangle and 'punch' again. C :-)
          Peter
          "Panchdara" <panchdara@gmail.com> wrote in message
          news:edjjo2$dj6$1@forums.macromedia.com...
          | Thanks
          | Hugh
          • 2. Re: Convert circle (ellipse) to letter &quot;C&quot;
            Level 7
            Fantastic Peter. You are a star! Learning the different methods to skin the
            same cat between different apps is quite frustrating sometimes ... but your
            method worked flawlessly.
            Cheers
            Hugh
            PS.... great newsgroup.
            "PJR" <flash@SLICEreclusivebillionaire.com> wrote in message
            news:edjkkt$ejm$1@forums.macromedia.com...
            > the shift key)
            > Peter
            > I
            > | Thanks
            > | Hugh
            • 3. Re: Convert circle (ellipse) to letter &quot;C&quot;
              Level 7
              Great, I'm glad it worked for you, reading it back to myself I
              thought it was less than clear but you obviously worked it out :-)
              I agree learning new apps when you have one you understand is
              difficult. I used to own Micrografx Picture Publisher v8, (in fact I
              still do) It was a great programme, but I just wasn't learning FWs
              while I had it on my system. I used to run back to it everytime I got
              stuck. I only really started to make progress after I took the plunge
              and removed it from my system altogether.
              Good luck with your future endeavours.
              Peter
              _____________________________
              "Panchdara" wrote in message ...
              the
              your
              | Cheers
              | Hugh
              down
              | > the shift key)
              were
              | > Peter
              can
              | > I
              but
              | > | Thanks
              | > | Hugh
