2 Replies Latest reply on Sep 6, 2006 8:48 AM by Newsgroup_User
    Load movie, delay play
    Level 7
      How do i load an external .swf file into a movie clip, and delay the
      playing of said movie clip?
      I am able to load the .swf, but it plays right away. Although it works
      fine on my local hard drive, online it will take some time to load
      before playing. I need to get my timing down exactly.
      Any ideas?
      Seth Meranda
      smeranda2<at>unl<dot>edu
        • 1. Re: Load movie, delay play
          Level 7
          place stop(); in the first or whatever frame you want it stop.
          Set up preloader, get it to play only when entirely cached.
          Forum is full of 'preloader' posts, including samples...
          Best Regards
          Urami
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: Load movie, delay play
            Level 7
            I'm not sure the preloader will solve the issue...
            The .swf is setup to load on the fifth frame. Will the preloader (which
            occupies the first two frames) account for a .loadMovie on the fifth frame?
            In case it helps, the loaded .swf file is a file which loads an .flv
            file. So I have one main .swf file which loads child .swf file (which in
            turn loads an .flv file) on the fifth frame of the main .swf. Make sense?
            Seth Meranda
