1 Reply Latest reply on Sep 2, 2006 9:20 AM by RoboWizard
    What Project Format should I use?
    pepsisc
      Hello: I am new to Robohelp. I just looked at "Start the New Project Wizard" and I am confused on what I should use. My OS is Windows XP Pro, SP2 and I write applications using Visual Basic 6 Enterprise Edition.
      I want to be able to write help files that can be accessed via a HELP menu of an application I have written/write or by using the "F1" key. The applications are installed on each PC but the data files are on a servered.
      Can somehelp and get me started? I appreciate it.
      Thank you
        • 1. Re: What Project Format should I use?
          RoboWizard Level 4
          Hi pepsisc and welcome to our community
          From what I've seen so far, I'm guessing your best bet will probably be Microsoft Compiled HTML Help. (.CHM format)
          I say this because even though your data files are server based, you said your application file that calls the help is installed on each local PC.
          Hopefully this helps... Rick
