1 Reply Latest reply on Sep 1, 2006 2:15 PM by Newsgroup_User
    I WILL PAY FOR HELP!!!
    kypsul
      Ok,
      I've been working on this way too long and I don't understand scripting well enough to make this work. I need to make the following script flip (not crossfade) 17 images in a sequence. I also need the same script to work in multiple movie clips that are contained within the same master swf. Here is the code:
      //-----------------<image crossfade - Mov1>-----------------\\
      var dyArray1:Array = new Array(17);
      dyArray1[0] = "image0.jpg";
      dyArray1[1] = "image1.jpg";
      dyArray1[2] = "image2.jpg";
      dyArray1[3] = "image3.jpg";
      dyArray1[4] = "image4.jpg";
      dyArray1[5] = "image5.jpg";
      dyArray1[6] = "image6.jpg";
      dyArray1[7] = "image7.jpg";
      dyArray1[8] = "image8.jpg";
      dyArray1[9] = "image9.jpg";
      dyArray1[10] = "image10.jpg";
      dyArray1[11] = "image11.jpg";
      dyArray1[12] = "image12.jpg";
      dyArray1[13] = "image13.jpg";
      dyArray1[14] = "image14.jpg";
      dyArray1[15] = "image15.jpg";
      dyArray1[16] = "image16.jpg";
      // Script to load two pictures and cycle them with a fading effect.
      // Note: this looks a lot better with 30 frames/second.
      var showTime:Number = 500 // milliseconds the picture shows at 100% alpha.
      for(var i:Number=0; i<17; i++){
      var mc1 = this.createEmptyMovieClip("mc_Img"+i, i);
      mc1.loadMovie("images/home/Mon1/image"+i+".jpg");
      mc1._alpha = 0;
      var duration:Number = 21; // milliseconds per alpha change (framerate).
      var count:Number = 0;
      var alphaPhase:Number = 1;
      var alphaCount:Number = 0;
      var imgIndex = 0;
      function picSwap1():Void {
      count++;
      if(count >= (showTime/duration)) {
      alphaCount += alphaPhase;
      // fade the current image out
      this["mc_Img"+imgIndex]._alpha = 100-alphaCount;
      // fade the next image in, modular division is used with the array length
      // to keep the indices within bounds of the array
      this["mc_Img"+(imgIndex+1)%dyArray1.length]._alpha = alphaCount;
      if(alphaCount >= 100 || alphaCount <= 0) {
      count = 0;
      //alphaPhase *= -1;
      // instead of reversing alpha phase, step along to the next image
      //and reset alphaCount
      imgIndex = (imgIndex+1)%dyArray1.length;
      alphaCount = 0;
      this.mc_Img0._alpha = 100;
      var intervalId:Number = setInterval(picSwap1, duration);
      //-----------------</image crossfade - Mov2>-----------------\\
      This works great by itself (in a single movie clip) and if I want it to cross fade. As soon as I try to apply it to the other 8 movie clips...with a different set of images in a different folder and changing the name of the array etc...the timing on the sequences syncs with the other sequences and ignores the duration/showtime. I would like to lose the crossfade and also have independant control on the duration/showtime over multiple movie clips contained in one master swf.
      PLEASE PLEASE someone...anyone...if you know how to do what I am trying to do please let me know...when finished...i can pay the person a reasonable amount for sorting this out for me.
      Thank you in advance,
      Kyle
        • 1. Re: I WILL PAY FOR HELP!!!
          Level 7
          What does your code look like for the movie clips?
          Dan Mode
          --> Adobe Community Expert
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          *THE online Radio* http://www.tornadostream.com
          *Must Read* http://www.smithmediafusion.com/blog
          "kypsul" <webforumsuser@macromedia.com> wrote in message
          news:ed9uj8$jb8$1@forums.macromedia.com...
          > Ok,
          > well
          > is the
          > code:
          > mc1._alpha = 0;
          > var imgIndex = 0;
          > count++;
          > count = 0;
          > //alphaPhase *= -1;
          > alphaCount = 0;
          > cross
          > have
          > do
          > amount
          > Kyle
