10 Replies Latest reply on Sep 16, 2006 9:14 AM by extol
    Modeling vegetation
    extol Level 1
      I downloaded a bunch of plant and flower models to use in my game scene. There's probably about 30 models altogether. The problem is after adding them, my movie now runs a lot slower. I assume this is because of all the polygons to make the leaves and such for the plants. Does anyone know any good tutorials for making trees, shrubs, plants, etc. that look halfway decent, but won't slow down Director too much? Thanks for any input on this!
        • 1. Re: Modeling vegetation
          Minds Eye Level 1
          Hi Extol,
          If you have polygons that make up the leaves of your trees, I'd imagine you'd have millions of faces in your 3D member.
          Yes, that would slow things down dramatically.
          My recomendation would be to use a rendered output of each tree (from 3D MAX for example) and apply each to a number of planes.
          You therefore will only have 2 faces per tree.
          As you move the camera around you'd need to make sure the trees are pointing towards it.
          As I'm such a nice guy, I've quickly rendered you two trees from 3DS MAX and placed them on my website for you to download:
          www.the-mindseye.co.uk/download/trees.zip
          You might want to scale down the images, depending on how far the trees are from the camera
          Good Luck,
          Trevor
          The Minds Eye
          • 2. Re: Modeling vegetation
            extol Level 1
            You are beyond nice! Thank you for the trees and the suggestion. I will definitely try that method. Thanks again!
            • 3. Re: Modeling vegetation
              Minds Eye Level 1
              Hi Extol,
              I've created a very simple Director movie for you download:
              http://www.the-mindseye.co.uk/download/3D trees.zip
              It generates 200 3D trees as it starts up.
              Regards,
              Trevor
              The Minds Eye
              • 4. Re: Modeling vegetation
                extol Level 1
                Thanks a ton! That helped out a lot. I am still having one problem. I want to put the trees into my 3d scene that I exported from 3ds Max. But now the trees are facing the wrong way (and rotate wrong). I tried changing the pointAtOrientation, but could not figure out how to make it match the angle of my scene. Is there a way to make the tree models have the same directions for up, right, forward, etc. as my perspective view from 3d s max?
                • 5. Re: Modeling vegetation
                  tyree_2 Level 2
                  you can use optimize or multires on your trees in max to bring the polygon count down and export the trees. as for as the camera. make a camera in max and do the rotations in max and export that. it wont show in the preview but it is there. use 3dpi and you should find it easy enough. keep in mind 3d is a visual medium not a programming one. all the work should be done in the 3d authoring environment. that will save you a lot of time
                  here is 3d scene that would have been impossible if I tried to program it in
                  a very simple test scene, note the camera work, does not use any video textures standard textures meant to look like a game
                  http://www.bleed3d.com/tree%20path%206.htm
                  • 6. Re: Modeling vegetation
                    extol Level 1
                    Thanks for your reply, tyree_2. I will try exporting as you suggested. As for the rotation, I'm not trying to do an animation, scene, or pan or anything. I had a plane with a tree image that would rotate to always be facing the player. It looks very decent and is very fast because it only has a couple faces. I can do it with a blank 3d scene, but when I try to put them in my 3d scene, the angles get messed up.
                    • 7. Re: Modeling vegetation
                      tyree_2 Level 2
                      may be because there is more than one object and they each have a different rotation on them. x one object isnt the same as x on another. again if you use a camera in max doing the motion you want and export that. you wouldnt have to be concerned with the different values of each objects rotation
                      • 8. Re: Modeling vegetation
                        extol Level 1
                        Maybe I'm misunderstanding you, but I don't see how I can know the motion I want. The camera follows the player. So I can't tell which ways they are going to go. The method that The Mind's Eye gave me works, it's just misaligned with my view.
                        • 9. Re: Modeling vegetation
                          Minds Eye Level 1
                          Hi Extol,
                          The problem you are encountering is because of different coordinate systems of 3ds max and Shockwave 3D. In the default 3ds max perspective window, Z points up, X goes to the right, and Y points into the screen. In Shockwave 3D this view corresponds to a coordinate system where Y is up, X goes to the right, and -Z points into the screen.
                          Maybe you can rotate all your objects in max before you export to w3d?
                          Regards,
                          Trevor
                          The Minds Eye
                          • 10. Re: Modeling vegetation
                            extol Level 1
                            Thanks for the info! I figured out how to solve the problem. I put an up-vector in the pointAt() property for each tree. Like this:
                            theTree.pointAt(camLoc, vector(0, 0, 1))
                            Now it has the right angles because it is using Z as it's up. Thanks for all your help guys!
