5 Replies Latest reply on Sep 7, 2006 12:57 PM by Newsgroup_User
    Have no FLash
    parentaladvisory
      Hello,
      i was amazed with AS3 that decided to buy Flash.
      But my only problem is if I buy Flash8 can i learn AS3?
      ANd if flash9 is out do i have to upgrade to flash9 for AS3 because the only reason I want to get flash is because the AS3.
      THANK U
        • 1. Re: Have no FLash
          Level 7
          parentaladvisory,
          Careful! AS3 is not available in Flash until the next release.
          Sure. :) You can learn AS3 even if you don't buy Flash. AS3 is a
          language, and the API is available free online.
          > is because the AS3.
          If you purchase Flash 8 now, you'll have free access to the Flash
          Professional 9 ActionScript 3.0 Preview release, which is an ALPHA release
          of Flash 9 (basically, just Flash 8 with AS3 publishing capability tacked
          on).
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Have no FLash
            parentaladvisory Level 1
            thnx that helped alot :)
            but i want use my fnished AS3 script, I would have to have flash right?
            • 3. Re: Have no FLash
              Level 7
              parentaladvisory,
              Glad to help.
              To "use" AS3? You mean publish (compile) an ActionScript 3.0-based SWF?
              For that, you would either need the alpha software I mentioned or Flex
              Builder 2.
              David Stiller
              • 4. Re: Have no FLash
                Are there any books for AS3?
                And if flash9 is officialy released and i have flash8 would i have to upgrade to flash9 to use AS3
                • 5. Re: Have no FLash
                  Level 7
                  parentaladvisory,
                  I have no idea. Flex Builder 2 is already a commercial release, and it
                  uses AS3 -- so my guess is, yes.
                  You got it. Or, as I said, download the alpha.
                  David Stiller
