7 Replies Latest reply on Sep 6, 2006 10:51 AM by jfilan
    Parsing XML
    jfilan
      I have the following XML file that I am trying to parse but I am having some trouble parsing the children nodes (is that what they are called?). I can't seem to find the proper syntax to parse XML children. For example, I want to output all the children nodes of lineitem1(i.e. skunumber, weight, color, clarity, cut, clarification.) and lineitem2 (i.e. skunumber, metal, style, size) and combine them all on one line. I know this is possible and probably very easy. I am looking for a hint on syntax with using my XML file below and then I can probably take it from there.
      Also, in lineitem1 and lineitem2 there are fields called unitprice. They both have a value. What is the best way to add these two fields together and output just that total number?
      I appreciate all help and responses.
      Josh
        • 1. Re: Parsing XML
          MikerRoo Level 1
          If you save your XML as a file called "ForumCart.xml" then the attached code should get you started...
          • 2. Re: Parsing XML
            Level 7
            Another way to skim this XML cat.
            XMLobj = your XML data as a CF xmlOjb.
            <cfloop
            from="1"
            to="#arrayLen(XMLobj.orderrequest.lineitems.xmlChildren)#"
            index="i">
            <cfloop
            from="1"
            to="#arrayLen(XMLobj.orderrequest.lineitems.xmlChildren .xmlChildren)#"
            index="j">
            <cfoutput>
            #XMLobj.orderrequest.lineitems.xmlChildren
            .xmlChildren[j].xmlName#
            #XMLobj.orderrequest.lineitems.xmlChildren .xmlChildren[j].xmlText#
            </cfoutput>
            </cfloop>
            </cfloop>
            Someways you can create xmlObj.
            <cfile action="read" file="file.path.xmldoc.xml" varible="rawXml">
            <cfset xmlObj = xmlParse(rawXml)>
            OR
            <cfxml variable="xmlObj">
            <orderrequest version="1.0" orderID="THX1138" issuedate="20060802"
            lang="en-us">
            <customer number="3263827">
            <fname>Ezra</fname>
            <lname>Pound</lname>
            </orderrequest>
            </cfxml>
            OR
            <cfsavecontent variable="rawXML">
            lang="en-us">
            <fname>Ezra</fname>
            </orderrequest>
            </cfxml>
            </cfsavecontent>
            <cfset xmlObj = xmlParse(rawXML)>
            OR
            <cfhttp url=" http://#CGI.SERVER_NAME##sWebFolder#/ForumCart.xml"
            method="get">
            <CFSET sXML_Raw = CFHTTP.FileContent>
            <CFSET zXML_Data = XMLParse (Trim (sXML_Raw))>
            PS
            None of this code is tested or debugged. Expect to have to correct some
            syntax or the other.
            • 3. Re: Parsing XML
              jfilan Level 1
              Holy crap! Thank you so much. I see that all children data is getting parsed. How would I exclude the <description> node but keep everything else? Again, thank you so much. This is such a great starting point for me.
              Josh
              • 4. Re: Parsing XML
                jfilan Level 1
                Thank you Ian. Question, how do I get the children to only loop once? It keeps repeating itself about 12 times.
                • 5. Re: Parsing XML
                  MikerRoo Level 1
                  quote:
                  Josh
                  At the top of the source add this line:
                  <CFSET sPropertiesToIgnore = "description,polish">
                  Then in the innermost <cfloop> you would use something like:
                  <CFIF 0 EQ ListFindNoCase (sPropertiesToIgnore, sPropName)>
                  <CFOUTPUT> <b><i>#sPropName#:</i></b> #sPropVal#   </CFOUTPUT>
                  <CFELSE>
                  <!--- Here we Ignored property "#sPropName#". --->
                  </CFIF>
                  • 6. Re: Parsing XML
                    Level 7
                    In my version:
                    <cfoutput>
                    <cfif
                    XMLobj.orderrequest.lineitems.xmlChildren .xmlChildren[j].xmlName
                    NEQ "description">
                    </cfoutput>
                    </cfoutput>
                    • 7. Re: Parsing XML
                      jfilan Level 1
                      <CFELSE>
                      </CFIF>
                      Thank you almighty ColdFusion god.
                      Josh
