3 Replies Latest reply on Jan 19, 2009 12:47 PM by Newsgroup_User
    Converting XML to PDF
    ooba Level 1
      I know this is the Flex Group, but I'm getting no love from the Flash group.
      1. I need to build a thick client
      2. I have 0 experience with Flex or AIR
      3. I have built alot of Flash web components and a few thick clients
      4. I only have one week to get something working
      Can anyone tell me if it is even possible for Flash to generate a PDF file from an imported XML file? or to browse a systems and allow the user to select an xml file to load?
      I need to have the client select an xml file that and the thick client would then use a predefined xsl file and (missing this part) need to convert the xml out to a human readable PDF format.
      If you have another suggestion on how to do this please post suggestions.
      All I know right now is that I need to construct a thick client to do this, and being that Flash has been what I have built thick clients on before I'd like to do it in Flash rather than try and figure out how to do it in C# .Net in less than a week.
      Any input is greatly appreciated.
        • 1. Re: Converting XML to PDF
          Level 7
          "ooba" <marshale@ctc.com> wrote in message
          news:gl2klg$rap$1@forums.macromedia.com...
          >group.
          > select
          You'd need to upload the file to a server and have the server do this.
          > would
          > xml
          Depending on what server-side technology you are using, there are probably
          PDF libraries you could use.
          > this,
          > I'd
          > .Net
          You won't be able to do it with Flash or Flex alone.
          HTH;
          Amy
          • 2. Re: Converting XML to PDF
            ooba Level 1
            Most definitely not what i wanted to hear.
            There is no server to connect to
            • 3. Re: Converting XML to PDF
              Level 7
              news:gl2nvk$1u7$1@forums.macromedia.com...
              You might be able to use AIR and Merapi. There might be a Java pdf library
              that can be used this way.
