10 Replies Latest reply on Sep 4, 2006 2:08 AM by
    clear frame
    jagguy99 Level 1
      q)when going to a another frame I don't want any object from pervios frame on it, how do i clear the frame?
      q)how do i stop loging in all the time on this forum, my remeber me is always checked whhen logging but every post I am still logging in.
        • 1. Re: clear frame
          Level 7
          please empty frame (fF) while authoring and simply send your timeline there whenever
          you want to get rid of content
          no idea, never used on line based forum, using regular news reader, no pages to flip through,
          no logins, no SLOW annoying browsing...
          Best Regards
          Urami
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: clear frame
            jagguy99 Level 1
            nextFrame(fF) ?
            I can't find any clear frame in help files
            • 3. Re: clear frame
              Level 7
              jagguy99 wrote:
              > nextFrame(fF) ?
              you can't clear frame while you run flash movie, there is no such thing in flash
              to just purge your stage. You need to make an Empty frame on your timeline and when
              you want to move there, simply use the gotoAndStop("labelNameofEmptyFrame"); action
              Best Regards
              Urami
              <urami>
              </urami>
              • 4. Re: clear frame
                sorry news reader??
                • 5. Re: clear frame
                  fdarweesh
                  Hello:
                  just in case all your Movies created Dynamicly (Attachmovie,createMovie,loadMovie)
                  in this case just add removeMovieClip unloadMovie command in order to clear objects from the next frame
                  try this:
                  at Frame 1:
                  _root.attachMovie("circle", "circle1_mc", this.getNextHighestDepth());
                  this.attachMovie("circle", "circle2_mc", this.getNextHighestDepth(), {_x:100, _y:100});
                  and at Frame 2:
                  circle1_mc.removeMovieClip();
                  circle2_mc.removeMovieClip();
                  wish this help
                  regards
                  Firas Darweesh
                  • 6. Re: clear frame
                    jagguy99 Level 1
                    //I can't remove the movie clip at all using unload or removeClip.
                    q)how can i remove the movieclip image?
                    var bmp1:BitmapData = BitmapData.loadBitmap("cave1");
                    this.createEmptyMovieClip("mc1", this.getNextHighestDepth());
                    mc1.attachBitmap(bmp1, this.getNextHighestDepth());
                    mc1._x=100;
                    this.createEmptyMovieClip("mc4", this.getNextHighestDepth());
                    mc4.attachBitmap(bmp1, this.getNextHighestDepth());
                    mc4._x=0;
                    mc4._y=0;
                    // trace(this);
                    mcnext.onPress = function()
                    nextFrame();
                    mc1.unloadClip();
                    mc4.unloadClip();
                    • 7. Re: clear frame
                      fdarweesh Level 1
                      Hello:
                      for your example you just need
                      bmp1.dispose();
                      in order to release the memory from bmp1
                      and in general ....
                      1- if you use attachMovie or createEmpyMovieClip()
                      you should use mc1.removeMovieClip() to delete it
                      2- if you use LoadMovie()
                      you should use unloadMovie
                      regards
                      Firas Darweesh
                      • 8. Re: clear frame
                        please could you help me too fdarweesh? how can i put a movie clip in front of another movie clip?(small box-big box)( i opened a topic but it couldnt be solved:( )
                        • 9. Re: clear frame
                          fdarweesh Level 1
                          hello:
                          just use
                          boxMc1.swapDepths(boxMc2);
                          Regards
                          Firas Darweesh
                          • 10. Re: clear frame
                            thank you soo much fdarweesh
