Hey there,
Strange problem with Captivate 1.01, that's happened on two
different PC with different microphones.
Was working with a file and adding/recording new audio for
some slides .. all working well then without warning every time I
recorded the audio it’s recorded noise..
Worked ok, moved to next slide press record and no go (no
settings changes, <30secs later).
If I record audio with screen capture it works fine .. loud
and clear … add audio after, no love…
Re-installed application, audio drivers, purchased a new
mic… and still, records ok if capture both, but not if I only
record audio alone. (and it worked before now doesn't, again no
settings changed)
??? any one had the same problem..
