1 Reply Latest reply on Sep 14, 2006 8:45 PM by CatBandit
    Importing Captured Movie Troubles
    cgauntt
      So, I've created a template. I've also created movie files. My movie needed some edits in terms of copy and pasting some backgrounds for a few slides to aid in the timing of my ojbects and presentation. Now that I've imported the movie into the template the timing of these slides / backgrounds seems incorrect again. Does this mean, I should simply just do my edits to the timing and backgrounds once I've imported it?
      It seems odd that importing would have any impact, because the preview of the original movie is fine.
        • 1. Re: Importing Captured Movie Troubles
          CatBandit Level 3
          Hi cgaunti, and welcome to the Captivate User Community!
          I've waited for hours hoping someone else would read your post and answer it - because frankly, you lost me at the corner. You said ...
          That confuses me. What could pasting backgrounds have to do with "aid in the timing of ... objects"??
          In general, your sentence ...
          ... is correct. That is, it's correct as far as I am able to follow the rest of your description. So here's my problem with your problem ...
          I guess I just don't understand what you are doing. You created a template ... then created movie files ... what's that about?? Are you inserting SWF or other animations into a custom template? That would jive with your comment about "timing", kind of.
          Tell you what: If you would try again to describe what you are doing and how you are trying to do it, then explain what you expect to see, and what you are seeing instead of that, I'll bet we can help. Okay? It's probably a "density" problem at my end, but I'd love to understand you better, so with your help . . .
