4 Replies Latest reply on Sep 17, 2006 4:13 PM by Rothrock
    Remove XML?
      I've loaded and XML file using
      but.onRelease = function() {
      -- How can I remove the xml file or replace it w/ another???
      nothings working for me
        • 1. Re: Remove XML?
          lunchBoxCoder Level 1
          • 2. Re: Remove XML?
            Rothrock Level 5
            The answer is in the help files that I"m sure you spent the last two days reading very carefully? :) It is a good idea to explain a bit more what "nothings working for me" means – it helps us not come up with solutions that you've already tried.
            In any event, I've had good luck with:
            That leaves myXML object ready to receive more data, but removes the data.
            • 3. Re: Remove XML?
              Ya know I was looking for it all weekend..
              But was looking at it from the whole file instead of just the node or attribute of the file...
              and ofcourse loading another file w/ load() doesn't replace it just add
              and there was no signs of a delete, unload or remove XML function in the docs.
              So thats where i got lost..
              Found it in the help docs
              • 4. Re: Remove XML?
                Rothrock Level 5
                Yeah, that is the trick with XML, you have to remember that the whole thing is also a node – sometimes we can't see the forest for the trees. Glad I was able to help.
