6 Replies Latest reply on Aug 22, 2006 5:59 PM by NSurveyor
    Format a text field
    Pe_ka
      Anyone that happends to know if there is a good way of preformat a string for currency?
      Example;
      I have a number = "1234567" that i want to look like this "1.234.567" or similar and eventually include a currency symbol such as "$".
      I have checked the manual but can not find it.
      Cheers
        • 2. Re: Format a text field
          abeall Level 3
          There's no built in way. Here's a function I made awhile back:
          //v2
          strSeperator = function(num,delimiter){//takes long number(or string) and incrementally inserts a character
          num=num.toString();//convert Numbers to String
          pos=num.length;//var 'pos' is used to add a seperator at
          while(pos>3){//while loop, starts at String right moves to left
          pos-=3;//move left to next seperator point
          n2=num.slice(pos,num.length);//get all characters after seperator point as new substring
          n1=num.slice(0,pos);//get all characters before seperator point as new substring
          num=n1+delimiter+n2;//combine before-substring + dilimiter + after-substring as new 'num' String
          return num;//return 'num' to where function is called
          //example
          myNum = 7625428765237;
          myNumFormatted = strSeperator(myNum,".")
          trace(myNumFormatted);
          • 3. Re: Format a text field
            NSurveyor Level 2
            abeall, your code doesn't like numbers with decimals! It's a simple fix, just pull out the decimal part, do the stuff, then reattach the decimal part.
            • 4. Re: Format a text field
              Pe_ka Level 1
              quote:
              abeal or NSurveyor,
              could you please edit the code so it can handle decimals?
              Cheers
              • 5. Format a text field
                abeall Level 3
                Good call, NS!
                Here's my fix, Pe_ka:
                replace this:
                pos=num.length;
                with this:
                pos = (num.indexOf('.')==-1) ? num.length : num.indexOf('.');
                What that ugly line does is check to see if there's a "." - that's what the ? and : are for - in the number, if there is a '.' then it starts at the dot, otherwise it starts at the end of the number(actually at this point converted to string). Seems to work, the one time I tested it :-)
                • 6. Re: Format a text field
                  NSurveyor Level 2
                  One slight fix, for numbers like: -123345123, which gets formatted as: -,123,345,123 (because it is negative and the number of digits is a multiple of 3)
                  sign = num<0 ? '-' : '';
                  num=Math.abs(num).toString();
                  return sign+num;
