4 Replies Latest reply on Aug 19, 2006 4:54 PM by Newsgroup_User
    Dump running movie to an avi or bmps?
    cratica
      Hello all,
      I want to create a trailer for my game. I would like to run the game and have some of the action dumped straight into an avi or sequence of bmps (tgas, jpgs, doesn't matter). Is there a way to do this? Basically a screen grab 30 time per second for a few seconds at a time.
      Thanks!!!!
        • 1. Re: Dump running movie to an avi or bmps?
          cratica Level 1
          btw, I am aware of the export function in Director. This only works however, if your content is time based in the score. The meat of the game all happens inside a script which is on a single frame. Therefore if I export using the built in utility, it will only export 1 frame. I need to be able to run the game (looping constantly in one frame in the score) while exporting for either a set period of time or until I hit escape.
          Anyone know how to frame grab a running Director movie in a single frame in the score?
          • 2. Re: Dump running movie to an avi or bmps?
            Level 7
            Here's an idea:
            There's an extra that will export jpgs:
            http://www.sharp-software.com/products/
            see the docs on how to use it to save out the file
            do this each time through your loop:
            set up a dummy graphic member,
            save the stage image to the dummy member each time through the loop,
            member("dummy").picture = the stage.picture
            counter = counter + 1
            save the image out to a file with above xtra, and increment the file
            name_counter.jpg each time
            cross your fingers it goes fast enough
            TR
            "cratica" <webforumsuser@macromedia.com> wrote in message
            news:ec5gim$jb3$1@forums.macromedia.com...
            > however,
            > happens
            > the
            > the
            > either
            > in
            > the score?
            • 3. Re: Dump running movie to an avi or bmps?
              Level 7
              There is almost no chance for that approach to work at 30 frames per
              second. You will probable have a much better chance of a good final
              output if you use a dedicated screen recorder program (There are loads
              of them- check out www.download.com or www.tucows.com for a few. Some
              may be free or inexpensive).
              If you do decide to try this method, though, I would recommend a slight
              alteration. Instead of trying to get the screen captured, translated to
              an image, and saved to a file on each step, just do the 1st two, and
              save out the files after that is complete. i.e.,
              In each iteration,
              Then, after you have all of your screens captured, save out the
              individual files
              • 4. Re: Dump running movie to an avi or bmps?
                Level 7
                Also, it might work faster by saving the grabs to a blank cast lib, then run
                a handler that saves them out to the files. I believe it said it only
                captured a few seconds at a time, so this might go faster at run time, then
                it can take it's time writing out files. This might improve it from almost
                no chance to a glimer of hope. :)
                TR
                "Mike Blaustein" <mblaustein@gmail.com> wrote in message
                news:ec7c0o$k5t$1@forums.macromedia.com...
                > second. You will probable have a much better chance of a good final output
                > if you use a dedicated screen recorder program (There are loads of them-
                > check out www.download.com or www.tucows.com for a few. Some may be free
                > or inexpensive).
                > an image, and saved to a file on each step, just do the 1st two, and save
