3 Replies Latest reply on Sep 15, 2006 2:07 PM by arkcto
    passing an Array Remote Object
    arkcto
      I am a newbie and I've been able to call Java methods when they return a simple String. However, I am unable to get a collection of Java objects. I get the following error message :
      Type Coercion failed: cannot convert mx.rpc.remoting.mxml::Operation@31717b1 to Array.
      I have a datagrid in my application that has to be populated by calling a method of a remote object.
      The remote object (Java class looks like this).
      public class PlayerService {
      public PlayerService() {
      public Player[] getPlayersAsArray() {
      Player[] players = new Player[3];
      Player rahul = new Player("Rahul",,"Dravid");
      Player sachin = new Player("Sachin","Tendulkar");
      Player saurav = new Player("Saurav","Ganguly");
      players[0] = rahul;
      players[1] = sachin;
      players[2] = saurav;
      return players;
      I've configured the destination in my service-config.xml as
      <destination id="PlayerService">
      <properties>
      <source>rpc.playerinfo.PlayerService</source>
      <scope>application</scope>
      </properties>
      </destination>
      My mxml application code is given below :
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.collections.ArrayCollection;
      import rpc.playerinfo.Player;
      import mx.utils.ArrayUtil;
      [Bindable]
      public var players:ArrayCollection;
      public var myPlayer:Player;
      </mx:Script>
      <mx:RemoteObject
      id="playMe"
      destination="PlayerService"
      showBusyCursor="true">
      <mx:method name="getPlayersAsArray">
      <mx:arguments>
      </mx:arguments>
      </mx:method>
      </mx:RemoteObject>
      <mx:ArrayCollection id="playerList"
      source="{playMe.getPlayersAsArray}"/>
      <mx:DataGrid dataProvider="playerList" width="100%">
      <mx:columns>
      <mx:DataGridColumn dataField="FirstName" headerText="FirstName"/>
      <mx:DataGridColumn dataField="LastName" headerText="LastName"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:Application>
      One question I have is, how does Flex know that what's returned is an array of Player objects. I did define the Player in an Action script file.
      package rpc.playerinfo
      [RemoteClass(alias="rpc.playerinfo.Player")]
      [Bindable]
      public class Player
      public var firstName:String;
      public var lastName:String;
      public function Player() {}
      but it appears that I have never actually used it in the mxml file.
      Thank you very much.
        • 1. Re: passing an Array Remote Object
          T._Ruggles
          You need to actually call the method (playMe.getPlayersAsArray()) and your binding should be to {playMe.getPlayersAsArray.lastResult}.
          HTH,
          Tom Ruggles
          FDS QA
          • 2. Re: passing an Array Remote Object
            JSSanders
            On your method in remote object there is a result attribute. Create a function to handle that result and then get event.result back as an arrayCollection.
            In your instance you dont 'have' to actually create a player object for each item that is returned in the array. you can just bind the results to the grid.
            Here is some sample code:
            <mx:RemoteObject id="playMe" destination="PlayerService"
            <mx:method name="getPlayersAsArray" result="handlePlayersResult(event.result as ArrayCollection)"/>
            <mx:arguments>
            </mx:arguments>
            </mx:method>
            </mx:RemoteObject>
            Then down in your script object create a Bindable variable like this:
            [BINDABLE]
            public var playerList;
            then a result handler function like this:
            public function handlePlayersResult( event: ArrayCollection)
            //then set the event result which is being sent into this function to the playerList //var
            playerList = event;
            Assuming your grid is set to that dataprovider of {playerList} and on application crationComplete you call the remoteObject mentioned above with that result handler it should work.
            • 3. Re: passing an Array Remote Object
              arkcto Level 1
              Thanks guys.
              JS, I got what you are saying. Now I don't have any error messages, but the data grid is blank.
              This is the mxml code. (I added your input)
              <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml">
              <mx:Script>
              <![CDATA[
              [Bindable]
              public function handlePlayersResult(event: ArrayCollection)
              players = event;
              </mx:Script>
              </mx:RemoteObject>
              <mx:DataGrid dataProvider="{players}" width="100%" creationComplete="playMe.getPlayersAsArray()">
              <mx:columns>
              <mx:DataGridColumn dataField="firstName" headerText="FirstName"/>
              <mx:DataGridColumn dataField="lastName" headerText="LastName"/>
              </mx:columns>
              </mx:DataGrid>
              </mx:Application>
              What is it missing ?
              Thank you so much.
