17 Replies Latest reply on Apr 24, 2007 5:13 PM by Riyaz7
    Remote object with java.
    sanclementetech Level 1
      I am trying to do something that should be really simple. I am trying use an MXML RemoteObject control to access a java class. This class works fine with data services, so I am assuming I have a configuration problem. It does not appear that a call to the java class method is being made.
      Here is my configuration for my flex-remoting-services.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="remoting-service"
      class="flex.messaging.services.RemotingService"
      messageTypes="flex.messaging.messages.RemotingMessage">
      <adapters>
      <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
      </adapters>
      <default-channels>
      <channel ref="my-amf"/>
      </default-channels>
      <destination id="ContactAddressTypeRO" >
      <properties>
      <source>com.gcloans.dao.flex.ContactAddressTypeAssembler</source>
      </properties>
      </destination>
      </service>
      The class is in a jar file that is in the lib directory.
      here is my application MXML file.
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.*;
      import mx.collections.*;
      import mx.controls.*;
      [Bindable]
      public var contactAddressList:Object;
      private function getDatabasesHandler(event:ResultEvent):void
      contactAddressList=event.result;
      private function faultHandler(event:FaultEvent):void
      Alert.show(event.fault.faultstring + " : " + event.fault.message, "The Error: " + event.fault.faultCode);
      </mx:Script>
      <mx:RemoteObject id="ro" destination="ContactAddressTypeRO" fault="faultHandler(event);">
      <mx:method name="find" result="getDatabasesHandler(event);" />
      </mx:RemoteObject>
      <mx:Button id="btnGet" label="Get" click="ro.find();" />
      <mx:DataGrid id="dg" dataProvider="{contactAddressList}" editable="true" width="100%" height="800" y="30">
      <mx:columns>
      <mx:DataGridColumn dataField="contactAddressTypeId" headerText="ID" editable="false" />
      <mx:DataGridColumn dataField="contactAddressType" editable="true" />
      </mx:columns>
      </mx:DataGrid>
      </mx:Application>
        • 1. Re: Remote object with java.
          CathyM
          Sorry, there is not enough information to determine the issue.
          The configuration and the mxml for calling the code look correct.
          To troubleshoot the issue, I would recommend that you do the following -
          (a) Enable logging on the server by editting the logging section in services-config.xml to 'info' or 'debug' level.
          Restart your server and check for these messages on the server console.
          (b) Enable logging on the client by adding <mx:TraceTarget level="2"/> for debug level trace on the client.
          You must have the debug version of the flash player installed and you'll find the log at C:\Documents and Settings\username\flashlog.txt for windows.
          By enabling both of these, hoping you're issue should become clear. It will be able to help you determine if the message is getting to FDS on the back-end.
          • 2. Re: Remote object with java.
            JFAM
            If you compile your MXML application locally in Flex Builder, maybe you should define the channelSet property of your RemoteObject instance, using ChannelSet and AMFChannel classes. If you don't, your client app will not be able to reach the remote AMF broker (the flex remoting gateway).
            Hope this helps.
            • 3. Re: Remote object with java.
              JeffreyGong
              Hi sanclementetech,
              The name of the file flex-remoting-services.xml has been rename to remoting-config.xml for the final release fo Flex2. And other config xml files have been changed as well. You may rename those files and try agian.
              This may solve your problem.
              Jeffrey
              • 4. Re: Remote object with java.
                I caught that, but it still does not work. Would be nice if the documentation actually gave you a step by step full configuration example. It may have something to do with the compile issue, but I wonder why if it is running on a server, that I would not be able to access the default channel?
                • 5. Re: Remote object with java.
                  After playing with this JFAM is correct. However if I set the endpoint for the remote object to /flex/messageborker/amf then I am working fine. I did not get into what it would take to setup a channel and channelSet programmatically, but I guess that work as well. Seems lame that I have to do this however, of course I don't necessarily understand how channels work either.
                  • 6. Re: Remote object with java.
                    chrisichris
                    I've got the same problem. How did you change the endpoint of the remote object. I don want to hardcode the ChannelSet and AMFChannel. I have tried to change the amf channels endpoint in services-config.xml in different ways but the client does not seem to pick that up. (Data-management-services make no problems.)
                    I use Eclipse WTP + Tomcat 5. The FDS webapp is deployed on http://localhost:8080/shopweb . The flex-app is compiled locally with FlexBuilder. I have the following 'standard' configuration:
                    ## file [services-config.xml]:
                    <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                    <endpoint uri=" http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                    <properties>
                    <polling-enabled>false</polling-enabled>
                    </properties>
                    </channel-definition>
                    ## file: [remoting-config.xml]
                    <default-channels>
                    </default-channels>
                    <destination id="org.shop.services.ImageService">
                    <adapter ref="java-object"/>
                    <properties>
                    <source>org.shop.services.ImageService</source>
                    <scope>application</scope>
                    </properties>
                    </destination>
                    ## AS class ImageService
                    var imagesRO:RemoteObject = new RemoteObject("org.shop.services.ImageService");
                    imagesRO.getTagNames.addEventListener(ResultEvent.RESULT,onGetTagNames);
                    imagesRO.addEventListener(FaultEvent.FAULT,onFault);
                    Now when I call the imagesRO.getTagNames I get a Net.Connect.Call.Failed error. The flex-log is:
                    'my-amf' channel endpoint set to http://localhost:8080/messagebroker/amf
                    'my-amf' channel settings are:
                    <channel id="my-amf" type="mx.messaging.channels.AMFChannel">
                    <endpoint uri=" http://{server.name}:{server.port}/messagebroker/amf"/>
                    <properties>
                    </properties>
                    </channel>
                    '61E9894D-9D3F-5DEE-8B27-5BB350AAB574' producer sending message '6B48B2EA-410C-41C9-837B-5BB350C9B67F'
                    'my-amf' pinging endpoint.
                    'my-amf' channel got status. (Object)#0
                    code = "NetConnection.Call.Failed"
                    description = "HTTP: Failed"
                    details = " http://localhost:8080/messagebroker/amf"
                    level = "error"
                    'my-amf' channel polling stopped.
                    'my-amf' channel connect failed.
                    '61E9894D-9D3F-5DEE-8B27-5BB350AAB574' producer channel faulted with Channel.Connect.Failed NetConnection.Call.Failed: HTTP: Failed
                    '61E9894D-9D3F-5DEE-8B27-5BB350AAB574' producer fault for 'DE194498-4C38-3129-7C63-5BB350B98623'.
                    '61E9894D-9D3F-5DEE-8B27-5BB350AAB574' producer fault for '6B48B2EA-410C-41C9-837B-5BB350C9B67F'.
                    level = "error"
                    As said I have changed the endpoint definition by hardconding the host,port and context but this does not work.
                    Thanks for the help,
                    Christian
                    • 7. Re: Remote object with java.
                      I had to hard code it in the remote object
                      <mx:RemoteObject endpoint="/flex/messagebroker/amf" id="ro" destination="myRO" fault="faultHandler(event);" >
                      </mx:RemoteObject>
                      I am trying to figure out a better way, because this method is not right!
                      • 8. Re: Remote object with java.
                        p_watson Adobe Employee
                        Hi Ken & Christian,
                        From the debug output posted, it looks like the problem is that Flex Builder can't resolve {context.root} for the endpoint:
                        In Flex Builder:
                        1. right click on the project and select properties
                        2. click on "Flex Compiler" in the list on the left
                        3. in the textField under "Additional compiler arguments", add an argument for the context root
                        -compiler.context-root /flex
                        (* for Christian it would be /shopweb)
                        4. In the debug, you should now see the context root included in the endpoint:
                        'my-amf' channel endpoint set to http://localhost:8080/flex/messagebroker/amf
                        Please post back if that resolves the problem.
                        regards,
                        peter
                        • 9. Re: Remote object with java.
                          chrisichris Level 1
                          Hi Peter,
                          Thank you so much. Setting the compiler-argument solves the problem, which took me a lot of frustrating time. (After the fact it is quite logical that flex needs to know the context-path.)
                          Christian
                          • 10. Re: Remote object with java.
                            Peter -
                            Thanks for the reply. I no longer get the error message, but I also no longer get an data. In fact it doesn't even look like the server is getting called. However, I noticed in my browser window that there was a message "Looking up crossdomain.xml". I do not have a crossdomain.xml. Do I need one?
                            • 11. Re: Remote object with java.
                              Hi Ken,
                              You should not need a crossdomain.xml policy file because by default mx:RemoteObject uses the FDS remoting proxy.
                              So you are saying that you get data back when you set the enpoint your mx:RemoteObject to "/flex/messagebroker/amf" right?
                              But when you remove that attribute and add the -compiler.context-root /flex argument to Flex Builder project properties - you don't get a connection error, but it doesn't return data, correct?
                              Have you implemented the debug settings suggested by Cathy ealier in this thread? If not, please do and post back all info in the console and the client error message, just snippets make it hard to determine exactly what's happening - thanks.
                              You should be seeing something like this in the serverconsole:
                              [Flex] Channel endpoint my-amf received request.
                              What is the URL that flexbuilder is launching in the browser?
                              What is the full URL to your FDS application?
                              regards,
                              peter
                              • 12. Re: Remote object with java.
                                Peter -
                                Yes
                                Yes, I have debug on. That is how I know that I am not seeing anything. When making a call using DataService it works fine.
                                I am not launching from flexbuilder.
                                http://localhost:8080/flex/TestArea/TestArea.html
                                • 13. Re: Remote object with java.
                                  Hi Ken,
                                  I'm somewhat confused as to why my suggested change to the FlexBuilder compiler setting would have any effect on your situation considering that you are compiling on the server? It shouldn't have any impact becuase the IDE compiler isn't being utilized.
                                  I understand that you are not getting any debug info for the request/response - what I'm interested in seeing is the info from the attempt to make the request. Please include error messages and any relevent debug output that will help us determine what the issue is.
                                  When the server instance starts up, what is the output for the "my-amf' channel?
                                  It should look someting like this:
                                  [Flex] Adobe Flex Data Services Build: 143451
                                  [Flex] Endpoint my-amf created with security: None
                                  at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/amf
                                  My best guess is that the {context.root } portion of the endpoint is being resolved incorrectly.
                                  To debug, let's try hardcoding that value in the /WEB-INF/flex/services-config.xml configuration file:
                                  <endpoint uri=" http://{server.name}:{server.port}/flex/messagebroker/amf"
                                  Is the change reflected in the server console when it restarts?
                                  at URI: http://{server.name}:{server.port}/flex/messagebroker/amf
                                  This is the equivilent of setting the endpoint attribute in the mxml tag.
                                  Does the RO call work now?
                                  regards,
                                  peter
                                  • 14. Re: Remote object with java.
                                    I am not compiling on the server.
                                    • 15. Re: Remote object with java.
                                      RajatBaid
                                      One of the solution is - While creating the project , use the option 'Compile Application on the server when the page is viewed.' under Flex Data Services.
                                      I tried this and its working fine.
                                      You should compile on the server
                                      • 16. Re: Remote object with java.
                                        That is a solution, but then why have the option of compiling and publishing? Which BTW runs much faster since I do not have to wait for the compile. At the end of the day, the better option is to not use remote objects and instead use Data Services.
                                        • 17. Re: Remote object with java.
                                          Riyaz7
                                          Thank you!
