1 Reply Latest reply on Sep 13, 2006 6:46 PM by tyree_2
    TAPER effect like 3dmax Modifier
    sinopsis Level 1
      Hi All.
      I want to emulate the TAPER modifier of 3D Studio MAX, but with lingo.¿Is this possible?¿any ideas?.
      Many thanks.
        • 1. Re: TAPER effect like 3dmax Modifier
          tyree_2 Level 2
          if your a 3d person I wouldnt advise trying to program your way into an answer
          3d is a visual medium not a programming one. You can use several copies of the object, the start, the middle object with the taper effect, and the end effect. Export it as a single file with three objects. hide the second two and have them appear behind the first one in succession. put the hide and visiblity scripts in frames. Another way without programming is to put bones on both sides of the object and push the tips inward
