Hi all, I have a solution but I would like to hear some comments about it:
I have a flash player 8 swf movie (as2) that needs to be loaded controlled and communicated by a flash player 9-10 (as3).
This was a nightmare for me until I solved it out with local connection. (AVM1 to AVM2 connection and viceversa).
Now local connection had to be established both on the AS2 and the AS3 movies.
I ran into the same problems everyone here are describing :
Error #2082: Connect failed because the object is already connected
Usually because several browsers were open the same time, and even several tabs in the same browsers.
What I did is as follows:
first an outline of the process:
1. load external movie with a query cache killer string :myMovie.swf?ck=1894677
2. on the loaded external movie get the querystring.
3. open local connection key in both movies - that has the key name of the querystring.
4. I had to create 2 connections (viceversa) so I made one key = querystring , the other = querystring+"_out"
5. BOOOM IT WORKS!!! - since each browser page has a different local connection key - there are no conflicts.
6. Tested with Firefox 3.5 at 2 tabs opened with the same site, two tabs of IE7, one chrome, one opera - all open at the same time!!!!!!
for the long explanation (this is not the entire code - just snippets .. so use this wisely)
I usually add a cache killer to my external loaded movies ( a string that changes the name of the downloaded swf file so it will not be cached by the
browser - and by that I am getting a fresh copy of the file , every time).
So instead of loading: myMovie.swf , I load myMovie.swf?ck=1894677 for example.
this can be done like this:
in the main as3 movie:
var AVM_lc:LocalConnection = new LocalConnection();
var AVM_listener:LocalConnection ;
var myClient:Object;
var randomLCname:String;
var randomLCnameOutgoing:String;
randomLCname = String(getTimer()) + String(Math.round(Math.random() * 10000));
randomLCnameOutgoing = randomLCname + "_out";
theMoviePath = "externalAs2movie.swf?ck="+randomLCname;
var movRequest:URLRequest = new URLRequest(theMoviePath)
movLoader.load(movRequest);
after the movie is loaded I create two local connections to the as2 movie:
//incoming
AVM_listener = new LocalConnection();
myClient = new Object();
AVM_listener.client = myClient;
myClient.gotoProjects = function () {
// a function to execute once I get a note from the as2 external loaded movie
try {
AVM_listener.connect(randomLCname);
} catch (error:ArgumentError) {
w(error.toString())
// outgoing whenever I want I do:
AVM_lc.send(randomLCnameOutgoing, "playAnime");
//or
AVM_lc.send(randomLCnameOutgoing, "resetAnime");
now in the loaded movie (for this example it is an as2 movie - but can be done on an AS3 movie as well, at least I think so...)
I am reading the querystring (it is different in as3.....):
in the external as2 that is loaded into the as3:
var avm1toavm2:String = _root.ck; // do not forget the _root in as2
var avm2toavm1:String = avm1toavm2+"_out";
// local connection instance to receive events
// stopAnimation event handler - a command to stop the animation - inside the as2 external movie
AVM_lc.stopAnimation = function(){
stop();
//etc.
AVM_lc.resetAnime = function(){
gotoAndStop(1);
AVM_lc.playAnime = function(){
gotoAndPlay(1);
// listen for events for "AVM2toAVM1" - it means from the as3 file to this as2 file
AVM_lc.connect(avm2toavm1); // avm2toavm1 this parameter was defined earlier in this code
//--------------- create a connection to comunicate with the as3 movie
var sendToAs3:LocalConnection = new LocalConnection();
function movieIsOver(){ // this is a function that will be executed when the as2 movie is over
sendToAs3.send(avm1toavm2, "gotoProjects");
stop();
-------------------------- complicated but works!!!!!
Can anyone comment?
Can I have hundreds of localConnections the same time (assuming I did not close the others, while shuting the browser?????)
Gidon
Koomkoom Multimedia
info@koomkoom.com
site:
www.koomkoom.com
I have the same problem with Windows AIR application. Also this issue appears after system awake from hibernation.
Steps to reproduce:
1) Connect to a LocalConnection.
2) Hibernate your Windows device and then wake it.
Result: LocalConnection works no more. You need to reboot device.
Adobe, please fix this issue.
OMG, can't even believe I wrote my comment 8 years ago.
FLASH IS DEAD.
I've moved on...
Gidon
